no stop lights
https://www.ausmini.com/forums/viewtopic.php?f=2&t=34560
Author:  min-E [ Mon Aug 06, 2007 9:45 pm ]
Post subject:  no stop lights
ok found out today i have no stop lights and number plate lights too.
tail lights fine just no stop lights.
as this is my first mini (1970 deluxe) silly question maybe but where are the fuses?
as i can gather ther are two in the engine bay. they are fine
im thinking it may be something else as the tail lights work :?:
the only thing that is not working is my indicator light in dash.
are the number plate lights the cause of my problems or could it be in the wiring or switches :?:
help please :roll:
Author:  Mike_Byron [ Mon Aug 06, 2007 9:51 pm ]
Very likely the brake light switch on the brake pedal has failed.
Author:  Spaceboy [ Mon Aug 06, 2007 9:51 pm ]
when this happened to me, it was the little hydraulic switch in the engine bay, look for a little cylinder with wires coming out of it thats piped into the brake lines.
that might be it.
Author:  Stuwey [ Mon Aug 06, 2007 9:51 pm ]
Dirt contacts on the fuses???
Mine did that a while ago. A touch of emery paper and off once more.
Author:  sports850 [ Mon Aug 06, 2007 9:52 pm ]
Number plate light should be a seperate thing as it's earthed and powered seperately . There may be a fuse up under the scuttle (near the windscreen wiper tube) behind the air cleaner . It's normally for the park lights but someone might have swapped things about , it's worth checking anyway . Failing that take the wire off the brake light swtch which is on the subframe directly below (sort of) the master cylinders and earth it (I think it's an earth type switch from memory) and see if the lights come on .
Author:  min-E [ Mon Aug 06, 2007 10:01 pm ]
damn... very quick responses cheers
after i fixed the clutch saturday though id give the brakes a good bleeding.
front drivers hose had a crack in it so had to replace it.
in doing so it was threaded at the top under that hydraulic switch thingy :lol:
so we had to pull it apart and chisel it loose.
so my guess is its the connections, will check tomorrow night after work.
not even faulty brake lights will stop me from going on my first run this sunday
maybe
thanks
