It is currently Wed Jul 16, 2025 7:45 pm
 Post subject: Oil cosumption
PostPosted: Thu Dec 16, 2004 9:04 pm
teh admin God
teh admin God
How much do you go through?
I put oil in every 2-3 days, about 200-300ml, so thats 100 ml a day :wink: . This is through general leaking and also thorugh the mini eating it.
It this too much?
Lets see some figures.
Sir Namibian CAMEL of MONGOLIA !!!
Vrilen Snyson Racing: Finding us all a Vrilen
Asparagus: Experience the versatility
PostPosted: Thu Dec 16, 2004 9:07 pm
thats heaps
mine doesnt leak at all
Inconspicuously Conspicuous
PostPosted: Thu Dec 16, 2004 9:13 pm
my 850 is using about 1L per 100km but the rings are ROOTED :D
PostPosted: Thu Dec 16, 2004 10:04 pm
My mate had a Morris 1100 from new, it used to use a pint (~600ml) in 400 miles- BMC told him that was normal!
I find the old A series varies a lot. Some use oil, others don't.
Our recond 1098 Clubbie used to do 3000 miles between changes without topping up (before we took it off the road). I guess the rings and bores are working fine!
My 1310 motor gets thru about 1L in 1500 miles but it's now done 45,000 miles and I do thrash it `a bit' 8)
PostPosted: Thu Dec 16, 2004 10:16 pm
Yeah I go through a fair bit. Probably put in about the same as that.
Mine leaks like a sieve & burns its fair share as well.
I'm hoping the new donk will be leak free. Putting plenty of breathers on it: side cover, timing cover, clutch housing. Since its going to be remote change I won't have to do that bastard of a seal where the selector goes into the rod change box.
dewey
dwightgunning.com
PostPosted: Fri Dec 17, 2004 9:55 am
Minie would be flat out using a Pint of OIL between a 3000km oil change.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Fri Dec 17, 2004 2:40 pm
Yeah mine goes through about 1 litre of oil every month or so. I can't tell you how many miles that is cause the gauge stopped working at 79,999 miles :roll: :lol:
Everytime I go to drive it , I just check the oil :wink:
