what are these for
https://www.ausmini.com/forums/viewtopic.php?f=2&t=34701
Page 1 of 2
Author:  min-E [ Sat Aug 11, 2007 3:14 pm ]
Post subject:  what are these for
ok as i am new to minis i may ask alot of questions like this one.
what are these valves for :?:
Author:  sports850 [ Sat Aug 11, 2007 3:18 pm ]
I think you forgot to add the picture :D
Are they under the rear bumper ? If so they are the valves for pressurising the hydrolastic suspension . It has a mix of alcohol and other bits in it under very high pressure and requires a hydro pump to increase the pressure . Do a search on hydro pump and you'll get some designs for pumps .
Author:  slinkey inc [ Sat Aug 11, 2007 3:19 pm ]
errrr....Which valves?
Author:  simon k [ Sat Aug 11, 2007 3:19 pm ]
which ones?
the ones that keep the air in your tyres, and let you put more in, or the ones in the engine that go down and up to let petrol/air in the motor, and let exhaust gases out?
Author:  Blokeinamoke [ Sat Aug 11, 2007 3:22 pm ]
Post subject:  Re: what are these for
they change the note in a trumpet - or a french horn. You can replacements from any good music stores
Author:  min-E [ Sat Aug 11, 2007 3:26 pm ]
yes i am on the music site. :roll:
pic on now
Author:  sports850 [ Sat Aug 11, 2007 3:26 pm ]
Woohoo , I win :D
Yes , Hydro valves for pressurising and depressurising the suspension . Don't try and pump it up with air , much too high a pressure for it , around 250-300 psi (from memory , anyone know for sure ?) .
Author:  drmini in aust [ Sat Aug 11, 2007 3:45 pm ]
sports850 wrote:
Woohoo , I win :D
Leyland Black book says with new displacers, pressurise to 350psi early and 400 psi late models, for 1/2 hr. Then let down to pressures shown on chart in General Data for different models.
Helpfully, this essential? hydro information was omitted from General Data- in my 1976 book anyhow.:lol: :P
Typical Leyland.... :roll:
It's in the Scientific Publications #64 I think. Will search and find... :wink:
OK here we go-
Early 263psi
Late 282 psi
No dates or car numbers given for Oz made cars. :cry:
Author:  gafmo [ Sat Aug 11, 2007 9:06 pm ]
Don't you just adjust to prefered finger height..rather than a Number Specifiec by the Leyland :roll:
more of a question...why is one exhaust rusty and the other black with oil...is that a fakey
Author:  Spaceboy [ Sun Aug 12, 2007 2:10 am ]
nice spot!
looks like a fakey to me :mrgreen:
Author:  mini-dunger [ Sun Aug 12, 2007 2:12 am ]
I reakon its a fakey
Author:  drmini in aust [ Sun Aug 12, 2007 7:39 am ]
Yes that's what you do, height is more important than exact pressure.
I just use 3 fingers between the 165/70-10 tyre and the front wheel arch. :wink:
Author:  sports850 [ Sun Aug 12, 2007 7:46 am ]
I was only using the pressure as an indication of it being very high and way above a compressor (and not air ...) .
Author:  mickmini [ Sun Aug 12, 2007 12:28 pm ]
whatever height you want to set it to, i would still do this bit. it is the pressure test at higher than operating pressure to see if you have any leaks. although, i am guessing that this is not explicit in the leyland book, and it does not tell you how much the pressure is allowed to drop in the 1/2 hour to pass the test :roll:
michae
Author:  drmini in aust [ Sun Aug 12, 2007 4:32 pm ]
michae
That test is only if you fit NEW disdplacers, must be to flex the internals or something. NOT for normal pumpup of s/h ones it says.
