It is currently Wed Aug 13, 2025 3:56 am
PostPosted: Sat Aug 11, 2007 4:34 pm
My pedal pad fell off the brakes last night and I think it may be time to replace the master cylinder. I have a twin circuit master cylinder lying around that I was thinking of reconditioning and putting on the car. As far as I know all I need to do do convert to twin circuit brakes is install the master cylinder and replace the T-piece behind the clutch slave cylinder with two separate connectors to separate the front and rear brake circuits. Then the standard bias valve on the rear subframe should still do its job. And I'll connect the brake booster to the front circuit only.
Can anybody see a problem with doing this? I figure that assuming the master cylinder works then it would have to be an improvement safety wise. A while back I had somebody tell me that the master cylinder off a late model Rover (with the booster) will fit on. Can anybody confirm/deny this? I thought the firewall itself was different on the late model cars for the integrated-booster type master cylinders.
PostPosted: Sat Aug 11, 2007 4:40 pm
A lot of work for no real gain IMO
Blue
Keep shiny side up
PostPosted: Sat Aug 11, 2007 4:46 pm
Blue
If you get a leak in one circuit, you won't have brakes anyway. Brad couldn't bleed his up until he replaced both rear wheel cylinders.
The tandem MCs were fitted "to satisfy ADR requirements". :wink:
PostPosted: Sat Aug 11, 2007 5:05 pm
Ditto
Blue
Keep shiny side up
PostPosted: Sat Aug 11, 2007 5:33 pm
Replace both rear wheel cylinders with what?
PostPosted: Sat Aug 11, 2007 5:44 pm
new ones
PostPosted: Sat Aug 11, 2007 7:23 pm
Blue
Why won't you have any brakes ?
PostPosted: Sat Aug 11, 2007 7:29 pm
Because they don't seem to work like later ones on modern cars?
The tandem feature is illusory.
PostPosted: Sat Aug 11, 2007 8:37 pm
Is this just the non booster type on clubmans, or does it include the boostered type on rovers ?
PostPosted: Sat Aug 11, 2007 8:39 pm
I'm talking Clubby ones, 1977-78.
PostPosted: Sat Aug 11, 2007 8:51 pm
My brake man hates the tandem system on Minis, says they are a pain in the you know what.. :shock:
Users browsing this forum: No registered users and 275 guests
