It is currently Sat Jul 19, 2025 4:20 pm
 Post subject: clutch replacement
PostPosted: Mon Aug 13, 2007 6:15 pm
I was thinking of replacing the clutch in my car myself, I was wondering if its hard to replace the clutch in a round nose mini, if any special tools are required or is it just fiddly to do due the lack of room. Any feedback or ideas from others that have done this before I attempt in starting the job
Or
Should I just get it done by a mechanic?
1970 Mini Cooper S Mark 11
2006 Toyota Hilux SR5 4X4
PostPosted: Mon Aug 13, 2007 6:23 pm
you need a torque wrench and a flywheel puller, fiddly job, but as long as you follow the workshop manual to the letter, it's not that hard
PostPosted: Mon Aug 13, 2007 6:31 pm
No its not hard just fiddly...
i pulled mine out in my clubby (i know theres more room) the concept is exactly the same. would just be very fiddle - fddly in cluby so good luck with it :D
Its very straight forward
brenton
PostPosted: Mon Aug 13, 2007 6:34 pm
About two hours if you know what you are doing and you have all the tools. (I have done one in 45 minutes)
A couple of days if you don't know what you are doing. :lol:
PostPosted: Mon Aug 13, 2007 6:36 pm
It would be so much easier with a hoist!
PostPosted: Mon Aug 13, 2007 6:45 pm
Getting some of the bolts on the flying cover off can be hard. But really just fiddly. Takes a lot time if you have no idea, (like me and my dad did), but the workshop manuals help, a lot!
Getting the wheel off, on tow seperate engines for me has been easy using a flywheel puller from eBay. I've heard of others having big issues but time and patience will get it off. (Correct tools helps too :wink: )
PostPosted: Mon Aug 13, 2007 9:34 pm
Thanks for the advice
I will take the car to a mate’s mechanical workshop as he has a hoist and if I get stuck he will help me out
PostPosted: Mon Aug 13, 2007 9:35 pm
