Oil cosumption
https://www.ausmini.com/forums/viewtopic.php?f=2&t=3491
Author:  Namibian CAMEL [ Thu Dec 16, 2004 9:04 pm ]
Post subject:  Oil cosumption
How much do you go through?
I put oil in every 2-3 days, about 200-300ml, so thats 100 ml a day :wink: . This is through general leaking and also thorugh the mini eating it.
It this too much?
Lets see some figures.
Author:  68matic [ Thu Dec 16, 2004 9:07 pm ]
thats heaps
mine doesnt leak at all
Author:  mickmini [ Thu Dec 16, 2004 9:13 pm ]
my 850 is using about 1L per 100km but the rings are ROOTED :D
Author:  drmini in aust [ Thu Dec 16, 2004 10:04 pm ]
My mate had a Morris 1100 from new, it used to use a pint (~600ml) in 400 miles- BMC told him that was normal!
I find the old A series varies a lot. Some use oil, others don't.
Our recond 1098 Clubbie used to do 3000 miles between changes without topping up (before we took it off the road). I guess the rings and bores are working fine!
My 1310 motor gets thru about 1L in 1500 miles but it's now done 45,000 miles and I do thrash it `a bit' 8)
Author:  dewey [ Thu Dec 16, 2004 10:16 pm ]
Yeah I go through a fair bit. Probably put in about the same as that.
Mine leaks like a sieve & burns its fair share as well.
I'm hoping the new donk will be leak free. Putting plenty of breathers on it: side cover, timing cover, clutch housing. Since its going to be remote change I won't have to do that bastard of a seal where the selector goes into the rod change box.
dewey
Author:  1380 yellow devil [ Fri Dec 17, 2004 9:55 am ]
Minie would be flat out using a Pint of OIL between a 3000km oil change.
Author:  Lillee [ Fri Dec 17, 2004 2:40 pm ]
Yeah mine goes through about 1 litre of oil every month or so. I can't tell you how many miles that is cause the gauge stopped working at 79,999 miles :roll: :lol:
Everytime I go to drive it , I just check the oil :wink:
