It is currently Thu Aug 14, 2025 3:55 pm
PostPosted: Sat Feb 26, 2011 4:07 pm
I don't normally buy 'twin carbs' made up of two singles carbs, but I bought these because it was so complete and simply looked right, even down to one of the air cleaners having a perfectly located breather inlet (or outlet??).
What appears to be purposely made bracketry for throttle and choke.
Breather
No markings on the manifold.
Different bowls?
Linkage.
PostPosted: Sun Feb 27, 2011 1:27 pm
the carbys are off different models. The one on the right[viewed from under- neath ] looks like it's a early 850 or minor carby. The bowl is at a different angle so could be a minor carb.
The manifold looks like the ones that were around many years ago as this was a fairly std set up with same carbs.
a lot of work re-building them.
www.minisprintgt.com
Users browsing this forum: jason050377 and 247 guests
