britishvita wrote:
Mick wrote:
I thought about the home plating process for my gear as well, I have a SCR power supply here that will put out 0-30 DC volts and up to 25 amps.
Mick where else can one get a nice DC power supply that can put out some reasonable amps, I'm wanting one for some de rusting
info was discussed here:
http://www.ausmini.com/forums/viewtopic.php?t=34941&highlight=I've heard that you can use photocopier power supplies, any other ideas??
Computer power supplies are a great source of very cheap and very dependable current. It's because they are made in such numbers that you can get high output power supplies neatly packaged in a ready to use box and supplying 5, 3.3 and + or - 12Vdc. They make perfect battery chargers for the garage as they put out plenty of amps. (Usually around 15 amps available on the +12 volt rail...sound useful?)
Best bit is that a 300 watt switched mode power supply can be had from a little corner computer shop for around 20 to 30 dollars. Pay any more than that and you being ripped off. You can also get 400 ($30) or 500 watt units ($??) for a few pesos more if you need more juice.
The output wires are neatly colour coded and usually have a label showing which is the 12 volt, 5 volt wires etc. I would never buy a battery charger from supercrap again, those expensive little pieces of crap usually only supply less than a couple of amps cold.
If 12 volts is what you are after, then this is what you need to buy.
