It is currently Sat Jul 26, 2025 12:27 am
PostPosted: Thu Sep 06, 2007 8:04 pm
Hi Guys trying to get my RH indicators Both front and rear aren't working but the left ones are.
I have checked there is no current (12volt) on the Green-white cable.
I have check continuinuty from the stalk to the green white cable to the cable near the indicator and that is correct
Earth appears fine
New stalk
New Flasher unit
I have tapped into the green white wire direct and both front and rear indicator lights up
It appears that where the power is inserted into the line is missing.
Any Ideas???[/b]
PostPosted: Thu Sep 06, 2007 8:23 pm
Check for twelve volts at the contact on the indicator arm, you have already done everything else correctly.
The green/white goes all the way up to the indicator arm, check for twelve volts here. If there is none, and the left hand ones are working correctly, then it is the indicator arm contact (there's a few of these dying these days...). The left and right hand indicators get their 12 volts from the one source at the indicator arm, so this is where the buck stops.
If there is 12 volts here, then the problem will be at the plug above the pedals, or at the three way junction in the wiring loom under the window wipers.
PostPosted: Thu Sep 06, 2007 8:40 pm
This space for rent
/me nominates Mick for Resident Electrician status :lol: :lol:
PostPosted: Thu Sep 06, 2007 8:41 pm
Thanks, could I do with a Victorian license....
PostPosted: Thu Sep 06, 2007 10:00 pm
thanks Mick got it working, 5 hours later..... when i was chnging from the UK plug to the Aust plug I got the green-red wires wrong way round!! I was so careful but must be set up slightly differently
