Nuts and Bolts https://www.ausmini.com/forums/viewtopic.php?f=2&t=35342 |
Author: | gafmo [ Sat Sep 01, 2007 12:47 pm ] |
Post subject: | Nuts and Bolts |
Getting Ready to Rebuild a nice little 1275 Motor and collecting all the Odd's and sods Block, Rods, Crank Cam all Collected but just need the nessary cleaning & what not Carb, Alt, Starter all as per the engine in the Car now other than Head oil pumps I want to get all new Nuts and Bolts Other than these below what else do I need & what are the Bolts for Box to block List of Engine Bolts Timing Cover • 5 x Bolts Cap Head 5/16”UNF (3/4” Long) • 6 x Bolts Cap Head 1/4”UNF (7/16” Long) • 5 x Washers 5/16”PLN (5/8” OD) • 5 x Washers 5/16”SPR (1/2” OD) • 6 x Washers 1/4”PLN (9/16” OD) • 6 x Washers 1/4”SPR (7/16” OD) • 1 x Nut 5/16”UNF (1/2” Head) • 1 x Nut 1/4”UNF (7/16” Head) Coolant Circuit • 2 x Bolts Heater Tap 1/4” UNF (7/16” Head, 1/2” Long) • 2 x Washers Heater Tap 1/4” SPR (3/8” OD) • 2 x Bolts Radiator Top 1/4” UNF (7/16” Head, 1 1/2” Long) • 2 x Washers Radiator Top 1/4”PLN (9/16” OD) • 2 x Bolts (Water Pump) 5/16”UNF (1/2” Head, 2” Long) • 2 x Bolts (Water Pump) 5/16”UNF (1/2” Head, 1” Long) • 4 x Washers (Water Pump) 5/16”PLN (5/8” OD) • 4 x Washers (Water Pump) 5/16”SPR (1/2” OD) Thermostat (Short) • 3 x Bolts 5/16 UNC (1/2” Head, 1 1/2” Long) • 3 x Washers 5/16” SPR (1/2” OD) Engine Electrical • 2 x Bolts (Alt’ top) 5/16”UNF (1/2” Head, 2” Long) • 1 x Bolt (Alt’ Bottom) M8x20 • 1 x Nut (Alt’ Bottom) M8 NyLoc • 4 x Washers (Alternator) 5/16”PLN (5/8” OD) • 4 x Washers (Alternator) 5/16”SPR (1/2” OD) • 2 x Nuts (Alternator) 5/16”UNF (1/2” Head) • 2 x Bolts Starter Motor 3/8”UNC (9/16” Head, 1 1/4” Long) • 2 x Washers Starter motor 3/8”SPR (5/16” OD) • 1 x Bolt (A+ Distributor) 5/16” UNF (1/2” Head, 3/4” Long) Clutch Slave (Non verto) • 2 x Bolts (Cyl Mount) 3/8”UNC (9/16” Head, 1” Long) • 2 x Washers (Cyl Mount) 3/8”SPR (5/8” OD) • 1 x Bolt (Arm Stop) 1/4”UNF (7/16” Head, 1” Long) • 1 x Lock Nut (Arm Stop) 1/4”UNF (7/16” Head) Clutch Cover • 8 x Bolts 5/16”UNC (1/2” Head, 1” Long) • 8 x Washers 5/16”SPR (1/2” OD) • 8 x Washers 5/16”PLN (5/8” OD) Tappet Chest • 2 x Bolts 5/16” UNF (1/2” Head, 1 1/4” long) • 2 x Washers 5/16 PLN (5/8” OD) Pre A+ Distributor Drive • 1x Bolt 1/4”UNF (7/16” Head, 3/4” long) • 1x Washer 1/4”SPR (3/8” OD) Fuel Pump • 2 x Bolt 5/16” UNC (1/2 Head , 1 1/2”long) • 2 x Washers 5/16” SPR (1/2” OD) • 2 x Washers 5/16” PLN (5/8” OD) Oil Filter Housing • 2 x Bolt 3/8” UNC (9/16” Head, 1” Long) • 2 x Washers 3/8” SPR • 2 x Washers 3/8”PLN (15/16” OD) Manifold Bolts • 6 x Bolt 5/16 UNF (1” Long) • 6 x Washers 5/16” SPR (1/2” OD) • 6 x Washers 5/16” PLN (5/8” OD) |
Author: | Mick [ Sat Sep 01, 2007 2:10 pm ] |
![]() ![]() ![]() My brain bleeds looking at the list. |
Author: | gafmo [ Sat Sep 01, 2007 2:18 pm ] |
Their is a lot isn't there |
Author: | henry the mini [ Sat Sep 01, 2007 2:23 pm ] |
Mate you should make a kit with all the bits in well mark bags. Ie This bag is for the clutch cover. I would buy it. |
Author: | Monster Mini [ Sat Sep 01, 2007 5:39 pm ] |
gaf mate im sure yor missing a nut and your It..... ![]() ![]() ![]() ![]() |
Author: | gafmo [ Mon Sep 03, 2007 8:38 pm ] |
Come one whats the bolts that attaches the Box to the Block |
Author: | drmini in aust [ Mon Sep 03, 2007 10:12 pm ] |
gafmo wrote: Come one whats the bolts that attaches the Box to the Block
1/4 UNF, there are several different lengths there. I'm stripping one tomorrow so I'll measure `em. ![]() |
Author: | gafmo [ Tue Sep 04, 2007 9:21 am ] |
Great timing...non of the Above need to be specific Grade's ![]() |
Author: | drmini in aust [ Tue Sep 04, 2007 10:12 am ] |
Most of those bolts are Grade 5 (3 lines on head). accept nothing less. If 6 lines = Grade 8. ![]() |
Author: | Wombat [ Tue Sep 04, 2007 12:56 pm ] |
OK that's the application list - what about a shopping list ? ![]() |
Author: | gafmo [ Tue Sep 04, 2007 6:39 pm ] |
Author: | gafmo [ Tue Sep 04, 2007 6:40 pm ] |
Author: | drmini in aust [ Thu Sep 06, 2007 7:11 pm ] |
OK I just stripped an 1100S (thick flange block) off a rodchange box. front of box- 1/4 UNF x 1.5" long, 5 off 1/4 UNF x 1.0" long, 1 off rear of box- 1/4 UNF x 1" long, 4 off 1/4 UNF nuts , 2 off (go onto studs) This list doesn't include the hollow dowel near the clutch housing, it had no bolt in it but many do. ![]() |
Author: | gafmo [ Thu Sep 06, 2007 7:27 pm ] |
I would say that complette'sthe list excpt the last one you mentioned Cheer's it will go into the how to's Listings ![]() |
