It is currently Thu Aug 07, 2025 2:21 am
PostPosted: Sat Sep 08, 2007 4:39 pm
hi, i'm woundering how people adjust there throttle cable when they are installed.
i put medium tension on the cable and then tighten the nut up. i have been have problems with the cable sticking when you first touch the pedal. it;s hard and crunchy then goes soft, but after a while driving the pedal feels perfect.
whats causing this?
PostPosted: Sat Sep 08, 2007 5:32 pm
Is the cable new? Have you tried lubing the cable at all?
PostPosted: Sat Sep 08, 2007 5:37 pm
Sounds like you need a new accelerator cable, or something else needs lubing up (Pedal or Carbie).
No more Minis!......For now.
PostPosted: Sat Sep 08, 2007 6:24 pm
hi, thanks for the replys,its a new throttle cable and the mini shop said that the cable doesn't need to be lubed.
PostPosted: Sat Sep 08, 2007 7:21 pm
This space for rent
Grab some graphite powder, and get a goodly amount onto the cable, and in the sheath. You'll be amazed the difference it will make to the throttle feel.
PostPosted: Sat Sep 08, 2007 10:34 pm
who sells the powder
PostPosted: Sat Sep 08, 2007 10:40 pm
You can get it from hardware shops.
The ends of the cable if forced through funny angles through the bulkhead or the carb end fittings can cause problems. This is where you will see them break as well.
PostPosted: Sun Sep 09, 2007 10:09 am
This space for rent
If you can't avoid a sharp turn in the cable, the graphite will help here too -- it'll delay the wear on the inner so it'll last longer :D :D
