help, snapped grease nipple!!!!!! https://www.ausmini.com/forums/viewtopic.php?f=2&t=35519 |
Author: | sunburst [ Thu Sep 06, 2007 6:58 pm ] |
Post subject: | help, snapped grease nipple!!!!!! |
Hi all, I just snapped off one of the grease nipples on my drum hub. Does anyone know any tricks to get the broken piece out i dont really want to do another hub up again. please any help much appreciated..... thanks Steve ![]() |
Author: | sports850 [ Thu Sep 06, 2007 7:11 pm ] |
How much of it is still showing , can you get a set of vice grips on it and wind it out ? Failing that get an easy out that will fit the hole in the middle and wind it out with that . |
Author: | buztoy [ Thu Sep 06, 2007 7:16 pm ] |
you can get a screw and bolt remover, you drill a hole in it and thread thing thing in and it should undo |
Author: | sunburst [ Thu Sep 06, 2007 7:17 pm ] |
Nah theres none of it sticking out, would i be able to get those easy outs from bunnings or something like that?? Thanks |
Author: | Mick [ Thu Sep 06, 2007 7:19 pm ] |
Really crappy ones can be had from supercrap, but I think you will end up having to get that out as well once it snaps. Nicer ones come from tool stores or specailty nut/bolt suppliers. P&N and SUTTON make nice ones. You might also try a sharp screw driver of the right width driven in the hole and turned counter clockwise....might save you a trip and a night... |
Author: | Wombat [ Thu Sep 06, 2007 7:35 pm ] |
A big nail might hold with help from a hammer then use vice grips on the nail |
Author: | volkmini [ Thu Sep 06, 2007 7:49 pm ] |
what type of thread and size are the front grease nipples |
Author: | mini-dunger [ Thu Sep 06, 2007 9:07 pm ] |
use an easy out, you dont want to drill, bash etc etc because you will force crap in there. grab a cheap set they will do the job fine. |
Author: | mad-mk1 [ Thu Sep 06, 2007 11:43 pm ] |
mini-dunger wrote: use an easy out, you dont want to drill, bash grab a cheap set they will do the job fine.
![]() it snapped for a reason.... i snapped an expensive easyout, in a door hinge. engineer still cant believe i drilled it out. |
Author: | mini-dunger [ Fri Sep 07, 2007 8:38 am ] |
quote me in entirety, otherwise my point is missed! i was thinking that maybe it broke because it had be hit in the past and was fractured? In all seriousness there is no better way is there? |
