1360 LS wrote:
Could be the master I don't know. But I still get floor boards first press of the pedal and only having pressed the pedal 2-4 times do i get pressure. I think I'll just bite the bullet and go see a brake expert.
If anyone has any other suggestions that can easily be done in a home garage please let me know.
hi mate, I'm no brake expert, but have gone through all this and had success. more than likely brake shoe adjustment needed. If adjusting doesnt make any difference, check the shoes and the drums( may need machining and bigger shoes). Is fluid flowing the same rate from all the lines? maybe blockage in one. Is m/c ok. bleed it to check. i thought mine was honky dorry but it was stuffed. I feel your pain brother, may it be releived without fleecing you of large somes of cash
Cheers, Anthony.
