It is currently Wed Aug 06, 2025 5:11 am
 Post subject: bypass hose
PostPosted: Tue Sep 11, 2007 3:54 pm
hey i took the engine out of my mini its a 1310 and the bypass hose was blocked off should i keep it blocked or should i unblock it ??
PostPosted: Tue Sep 11, 2007 4:00 pm
Bypass hose is there for a reason- it allows water circulation through the block and head during warmup, before the thermostat opens.
Unless you are going to drill a few 3mm holes in the thermostat, I'd put it back. But don't use the corrugated ones, a short piece of 1/2" heater hose is better and stronger. As used on Cooper S.:wink:
People will say "yeah the Metro etc had no bypass". But they had a sandwich plate under the thermostat and plumbing to suit, our old Minis don't.
PostPosted: Tue Sep 11, 2007 4:25 pm
oh k cool thankz for that really helps :D
PostPosted: Tue Sep 11, 2007 8:18 pm
nah, leave it blocked... I blocked it up on the engine I have in my cooper, and I can't get the bugger to keep warm at all, it's always cold
PostPosted: Tue Sep 11, 2007 8:56 pm
Haha- so, Simon, it's wearing out at an accelerated rate then. Check the thermostat actually works.:lol:
My 1360 has 125HP+, still has a bypass and it sits between 1/4 and 1/2 on the gauge ALWAYS. Radiator is a stock recond Cooper S/Mini Deluxe one.
If a Mini is getting hotter, with or without a bypass hose, you have other problems... :wink:
PostPosted: Tue Sep 11, 2007 10:25 pm
Skssgn,,, you probably have --->either no thermostat at all,,, or it`s stuck open ,,, or your temp gauge under reads ( &/or all of the above)
On the engines that i build i do block off the original bypass hose but i do fit another one from the back of the cyl head (where the heater take off outlet is) & fit a pipe into the top tank of the radiator for the other end of it. It does take a little extra time to warm up (not much tho) but works a treat in helping to even out the distribution of heat across the length of the cyl head & also helps cool things down more efficiently/effectively in stop/start traffic jam situations when pretty much stationary for ages.
if you like your heater fitted & working still too, then run that new bypass hose through the heater (no heater tap tho) & back to the radiator top tank fitting.
Radiator shops should only charge about $5-$10 to fit the pipe
then Bob `s your Aunty
easy-peasy
