Depending on what engine/crank you have i would also suggest that you check the big end and main journals are within tolerances to find out if its worth being machined then have the crank checked for "trueness" as well as crack tested prior to being machined (especially if it is an 1100 or 1275). I also agree with Dr Mini about having the cylinders in the block being checked for size and ovality, also have the block "dipped" to clean out all oil galleries and water galleries/jackets etc......
Especially agree with his statement...."Do it once and do it properly, or you WILL be doing it again, SOON!!"
Would also reccomend fitting a double row timing chain and gear set as well as the oil pump.....if you are going to go that far?? also get the head checked... valve stem seals etc.....
If so i reccommend that you have your gear box stripped inspected cleaned very thoroughly and excessively worn parts replaced as you dont want the disturbed crap in the bottom of your old g/box flowing up into your lovely brand new bearing (motor) etc and causing premature wear or worse and then having to do it "all" again therefore having to spend even more money sooner than you wanted to or thought you would have too. If you had someone do it for you then it would leave a bitter taste in your mouth (so to speak) but in the end it was your request.
