maths question for those in the know
https://www.ausmini.com/forums/viewtopic.php?f=2&t=35759
Page 1 of 2
Author:  mooman10_0 [ Fri Sep 14, 2007 7:20 pm ]
Post subject:  maths question for those in the know
after your opinions and other opinions have decided that rather than swapping my hydro bags front to back I will shorten the rear struts (as I have alot of these), and see if that works. Have eliminated possibility of being helper springs, knuckle joints/cups, or nething structural.
Question is how much do I remove to get the front to come up about an inch?
Note - Front already has two large spacers on it, dont want to add any more as they are very thick. They will stay on the front.
Any help appreciated :D
Author:  Harley [ Fri Sep 14, 2007 7:42 pm ]
I think you'll find removing material from the rear trumpets will not raise the front of the car. One of two other things will happen:
1. The rear becomes lower and the front stays as it is, or more likely,
2. The front will become even lower.
The way to get the front up by modifying the rear end you say? Add spacers.
:D
Author:  simon k [ Fri Sep 14, 2007 7:49 pm ]
5:1... so remove 5mm to remove 25mm of ride height.
but I'll say it again, I don't think it'll work, it'll just make the back lower because you're not equalising the pressure, you're just taking the height out of the rear
Author:  mooman10_0 [ Fri Sep 14, 2007 7:55 pm ]
If that is the case, what (in mm) is the max I could put in spacers on the front. At the moment I am near 4mm with two thick spacers, can I go more?
Author:  mooman10_0 [ Fri Sep 14, 2007 7:56 pm ]
I need about 1 inch in height to amke me happy at the front, and make it sit right. :D
Author:  Harley [ Fri Sep 14, 2007 7:59 pm ]
I wouldn't go more than that, if you go to the point where the amount of knuckle joint shaft engaugment into the trumpet is less than it's diameter it could pop out while driving.
Could be messy.
I think the solution is:
1. Pump up hydro system,
2. Fit new helper springs,
3. Put some gold in the boot,
4. Invest in Hi-lo's.
:D
Author:  mooman10_0 [ Fri Sep 14, 2007 8:08 pm ]
If i put one more washer in I would still have over the diameter, just I think. That would probably raise the car an inch aswell?
Author:  drmini in aust [ Fri Sep 14, 2007 8:16 pm ]
I have a `70 Matic with Cooper S/Clubby GT bags in front, MiniMatic/Mini-K bags in rear, comp hydro rear bumpstops.
With 2 full tanks it sits level, 3 fingers above tyre front and rear. 8) No washers or packing- in fact even the knuckle joints are original.:lol:
Author:  Harley [ Fri Sep 14, 2007 8:21 pm ]
Bear in mind the knuckle joint shaft has up to a 3 x 45 chamfer too.
That doesn't count.
Author:  mooman10_0 [ Fri Sep 14, 2007 8:28 pm ]
I have twin tanks, which are dead empty at the moment, will that help at all?
Author:  drmini in aust [ Fri Sep 14, 2007 9:12 pm ]
Filling the tanks adds weight at rear, this helps pull the front up as fluid is displaced forward.
What happens when you pump it up- does the front lift, or stay sitting on the bumpstops?
Author:  simon k [ Fri Sep 14, 2007 10:20 pm ]
nose of my cooper definitely comes up when I fill the tanks, likewise put anything heavy in the boot...
Author:  mooman10_0 [ Fri Sep 14, 2007 10:49 pm ]
Front comes up as I add fluid. Will try adding one more thin washer. Car is also on a slightly slanted forward driveway which wouldnt help (I think), and fill tanks. Should hopefully level out. Just realised it is a bit deceptive with the big arches on. If I go by the normal arch underneath it is about 2and a half finger at the front, and you can get four in at the back.
Author:  drmini in aust [ Fri Sep 14, 2007 11:12 pm ]
Back is normally a bit higher than the front, when at rest. Hydros do not have the `drag arse' look that some dry cars exhibit... because their owners think it's trendy. :lol:
Author:  mad-mk1 [ Sat Sep 15, 2007 12:56 am ]
oh dear :twisted: :P :lol:
