Rover brake master mounting (includes pictures) https://www.ausmini.com/forums/viewtopic.php?f=2&t=35861 |
Author: | brickworx [ Tue Sep 18, 2007 7:43 pm ] |
you would also want to modify the bolt(and bracket) going through the firewall... turn it around 180 degrees, otherwise your bonnet will never shut properly. |
Author: | lovely2 [ Tue Sep 18, 2007 7:48 pm ] |
brickworx wrote: you would also want to modify the bolt(and bracket) going through the firewall...
turn it around 180 degrees, otherwise your bonnet will never shut properly. Didn't think of that about the bolt. Thats what i was asking about what modification needs to be done to the booster bracket, because it looks like i almost have to cut threw the whole thing, to allow for the bonnet to shut. do you have pictures?? |
Author: | brickworx [ Tue Sep 18, 2007 7:51 pm ] |
my car is at work... and no camera at home for the other. can get some photos later if need be. i put a slit straight through the bracket 10mm wide. main bolt still holds it all together fine |
Author: | lovely2 [ Wed Sep 19, 2007 4:05 pm ] |
On the topic of rover brake boosters, how the hell do you get the servo back together? I've tried talc, and lube on the edges that rub on the metal but i can't get it to turn the last 20-30 degrees. Any hints ? |
Author: | Kennomini [ Wed Sep 19, 2007 7:55 pm ] |
Arn't the bonnit hinges on a rover more to the side? I had a 1/2 cut a while ago and that was one of the things I noticed ![]() ![]() |
Author: | drmini in aust [ Wed Sep 19, 2007 9:07 pm ] |
lovely2 wrote: On the topic of rover brake boosters, how the hell do you get the servo back together?
I've tried talc, and lube on the edges that rub on the metal but i can't get it to turn the last 20-30 degrees. Any hints ? Years ago I had the same problem on similar my Fiat brake booster (Bendix brand)- I cut 2 thick steel plates 6" square and drilled them to bolt on the front and back half. Then I welded a 12" long piece of 3/4 round bar to each, as a handle. Worked a treat. ![]() |
Author: | lovely2 [ Wed Sep 19, 2007 9:07 pm ] |
Kennomini wrote: Arn't the bonnit hinges on a rover more to the side? I had a 1/2 cut a while ago and that was one of the things I noticed
![]() ![]() Indeed they are, i believe they are in the same place as clubmen bonnet hinges. However the booster bracket (the bit in black in my picture) can be modified to suit. |
Author: | lovely2 [ Fri Sep 21, 2007 3:24 pm ] |
Post subject: | How to get the rover booster back together |
Is there anything angle iron can't do?? ![]() Handy door frame. ![]() |
Author: | brickworx [ Sat Sep 22, 2007 11:37 am ] |
Author: | lovely2 [ Tue Sep 25, 2007 11:31 am ] |
Hey steve, what did you do about pedals ? did you use rover pedals or the original round nose pedals ? |
