It is currently Thu Aug 21, 2025 8:08 am
 Post subject: Brake pedal
PostPosted: Wed Sep 19, 2007 1:57 pm
despite replacing the entire brake system - I cannot a get any feel from the brake pedal without one pump :twisted: what gives
it has a new master, cylinders, pipes and shoes. I has been bled well and had no air in the lines. the shoes have been adjusted to maxiumum travel without contacting the drums.
Its a four wheel drum system.
PostPosted: Wed Sep 19, 2007 2:12 pm
Give it a chance to bed in, it's pretty common for the brakes on a drum system to be a bit average if all the parts have been replaced. Drive in round for a bit then re-adjust, should come good.
PostPosted: Wed Sep 19, 2007 2:59 pm
chicken and egg
I need it better for rego so I might need to do some midnight runs
PostPosted: Wed Sep 19, 2007 3:22 pm
We don't have that problem in the ACT, it's very rare that they would do a brake test, or even sit in the car. :lol: It's the bureaucracy that's the problem.
A mate of mine had this problem recently with his NSW registered car, I can't remember if it failed the brake test or not but he got it through. After a week or two the brakes bedded in properly and they're pretty good now.
PostPosted: Wed Sep 19, 2007 3:31 pm
When I adjust mine, I try to get them so the shoes are just rubbing the drums, just enough that there is some resistance to turning them when the wheels are off, but only a little. That might be enough to get rid of that first pump.
Last weekend I stuffed it and had them too tight, they were fine until I did a hard stop, the shoes heated up, expanded and then they were dragging quite badly. When I eventually stopped to fix them (didn't want to mess up the convoy) there was smoke jetting out around the hand brake levers.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Wed Sep 19, 2007 3:32 pm
One obvious one - but can take a while to diagnose if you don't think of it is are the shoes on the right way with the correct "leading edge"?
Also if you've got twin leading shoe fronts sometimes they can get an air bubble stuck in the little pipe that runs between cylinders.
PostPosted: Wed Sep 19, 2007 3:47 pm
Yep he's right, very common problem if cyls have been changed. To see if this is the case undo the highest end of that pipe 1/2 a turn and bleed it there. :wink:
PostPosted: Wed Sep 19, 2007 6:31 pm
As i am doing a mechanic apprenticeship i have been told to adjust drums till it just binds the drum and u cant move it. When you put the wheel back on the force of spinning the wheel creates the perfect drag on the drums. Roadie it and check again.
I've been doing this to customer cars and never had any complaints back to me so i guess im doing something right :lol:
Users browsing this forum: No registered users and 176 guests
