ticking noise from motor?? https://www.ausmini.com/forums/viewtopic.php?f=2&t=35937 |
Page 1 of 2 |
Author: | lurker [ Fri Sep 21, 2007 10:14 am ] |
Post subject: | ticking noise from motor?? |
Ok now I'm sure when you were kids you did the same thing, pegged a playing card to the fork of your pushbike and when the wheel went round the spokes hit the card and you sounded like a motorbike. Anyway my 1993 auto Rover Mini is making that noise. When it idles at lights and especially exelarating it sounds as though someone has pegged a playing card to my wheel and I now sound like a motor bike. Anyway have any idea what that might be? Help needed thanks. |
Author: | meehal [ Fri Sep 21, 2007 10:17 am ] |
Hey, Im no mechanic just taking a stab... Could be sticky valves? You could try some valve stuff that helps get them lubricated (i think). Its available from places like supercheap, repco, autobarn usual car places, i think its like $10.00 Have you checked your oil as well? Cheers, Michael. |
Author: | Dylans Clubby [ Fri Sep 21, 2007 10:23 am ] |
i know its not oin the motor, but sortof in the area...wheel bearings? |
Author: | willy [ Fri Sep 21, 2007 10:48 am ] |
Exhaust leak. |
Author: | sports850 [ Fri Sep 21, 2007 11:07 am ] |
As willy said , exhaust leak , but look around the manifold gasket particularly . |
Author: | Anto [ Fri Sep 21, 2007 11:28 am ] |
I used to use bulldog clips. |
Author: | buztoy [ Fri Sep 21, 2007 11:57 am ] |
bearing in my altinator used to tick, and when reved hard it would wine |
Author: | -=MiniMafia=- [ Fri Sep 21, 2007 2:40 pm ] |
Im sorry, i cant help this ![]() The Mysterious Ticking Noise! http://www.youtube.com/watch?v=Tx1XIm6q4r4 |
Author: | Mister White Keys [ Fri Sep 21, 2007 3:03 pm ] |
I'm gonna go with exhaust as well. The two most common places are the manifold gasket and the gearbox mount. It's very easy for the manifold gasket to develop a hole especially if a couple of bolts have come a bit lose. Where the exhaust mounts to the gearbox is also a common problem as the welds sometimes crack. |
Author: | simon k [ Fri Sep 21, 2007 3:23 pm ] |
maybe someone pegged a playing card to one of your wheels |
Author: | lurker [ Fri Sep 21, 2007 3:28 pm ] |
Thanks for all your help. I'm taking it to Link tomorrow. See if they can fix it, seen as it does seem to be the Exhaust as I had a few guys look at it here at work. I checked for the playing card too, and that youtube video was a pisser, very clever you ausmini people. ![]() ![]() ![]() Thanks again ![]() |
Author: | MiniBob [ Fri Sep 21, 2007 3:31 pm ] |
[quote="-=MiniMafia=-"]Im sorry, i cant help this ![]() The Mysterious Ticking Noise! (in best Peter Sellars [Pink Panther] voice)...........it's a bemb ! |
Author: | Spaceboy [ Fri Sep 21, 2007 4:26 pm ] |
tappets? |
Author: | Mini Mad [ Fri Sep 21, 2007 4:47 pm ] |
Exhaust Leak, Large Tappet Clearance or worst cast engine bearing ![]() |
Author: | 1310/71 [ Fri Sep 21, 2007 4:55 pm ] |
Some left-field thoughts - 1. Check the alternator brackets (can produce a rythmic knock when really loose 2. Harmonic balancer - when the rubber perishes and wears, it can make a ticking sound that is more prominent on idle and starts to disappear as the revs get higher KB |
