ARP Bolt tension https://www.ausmini.com/forums/viewtopic.php?f=2&t=35970 |
Author: | Wombat [ Sat Sep 22, 2007 1:19 pm ] |
Post subject: | ARP Bolt tension |
Interesting link that cropped up on another forum http://www.aptfast.com/ARP_Additional_Stuff/ARP_notes_info/arp_t_specs.htm |
Author: | mini-dunger [ Sat Sep 22, 2007 5:28 pm ] |
i am surprised the use of arp lube changed the settings so much. |
Author: | drmini in aust [ Sat Sep 22, 2007 7:09 pm ] |
The most accurate way is to use a bolt stretch gauge, if you have one (I don't). ARP `Cooper S' bolts & nuts (3/8 UNF) are supposed to be 50lb/ft, torqued up 3 times using the ARP molylube in the bolt kit. These ARP nuts do not have nyloc inserts- it's the `stretching' of the bolts that keeps them tight. ![]() |
