5+6 speed gearboxes https://www.ausmini.com/forums/viewtopic.php?f=2&t=35983 |
Page 1 of 2 |
Author: | Spaceboy [ Sun Sep 23, 2007 5:39 am ] |
Post subject: | 5+6 speed gearboxes |
i think i'm about 10 years too late, but where do we get them from? ![]() ![]() also, who is this young whippaschnappa ![]() ![]() ![]() |
Author: | drmini in aust [ Sun Sep 23, 2007 7:25 am ] |
Q1- these were made by KG Engineering in Melbourne, but they are no more AFAIK. Matt TheMiniMan had one. ![]() Q2 NFI but he looks familiar. |
Author: | aaron [ Sun Sep 23, 2007 8:12 am ] |
I hope you jest Kev. ![]() |
Author: | drmini in aust [ Sun Sep 23, 2007 8:36 am ] |
(puts specs on )ooh yes `tis the master himself, GR!!! ![]() ![]() |
Author: | Kennomini [ Sun Sep 23, 2007 10:31 am ] |
How about this one; ------------------------------------------------------------------------------------------------------------------------------------------ KAD 5 speed racing gearbox, with LSD, CW&P, fully assembled KAD 5 speed Racing Gearbox The ultimate 5 speed gearbox on the market, fully assembled, with LSD diff, and crown wheel and pinion, full race specs, see description for all the info! This gearbox is a special order only item and a delivery time delay will apply, please either contact us at [email protected] or call us on 08-8177-1275 to find out the delay Price may vary (not by much) if items are specialy requested eg diff ratio etc... Freight may vary depending on urgency of this item also Price: $12,500.00 inc GST within Australia ------------------------------------------------------------------------------------------------------------------------------------------ $12,500 ![]() |
Author: | brett [ Sun Sep 23, 2007 11:36 am ] |
I have a 6 speed box in my Cooper S... Factory Fitment. Or you could try like I have fitted to my Classic Cooper S a 3.2 Diff, drops about 800rpm Cheers Brett |
Author: | dove grey 64 [ Sun Sep 23, 2007 12:11 pm ] |
if you want a kg 5 or 6 speed gearbox, call up john k, he works at northern mini parts, he can still make you one. becareful though i hear they arnt the strongest boxes around |
Author: | Timbo [ Sun Sep 23, 2007 5:10 pm ] |
Were they the gearboxes that used motorbike innards and had a sequential shift? Tim |
Author: | drmini in aust [ Sun Sep 23, 2007 5:20 pm ] |
NO, the KGs were a 5 or 5 speed dog box (similar looking to bike gears I guess) but the shift wasn't sequential. Gears were made by KG Engineering. |
Author: | mickmini [ Sun Sep 23, 2007 5:53 pm ] |
i thought the KG ones were 6 speed as well? |
Author: | Mini Mad [ Sun Sep 23, 2007 8:43 pm ] |
Haha love that old pic of Graham ![]() ![]() |
Author: | drmini in aust [ Sun Sep 23, 2007 9:44 pm ] |
mickmini wrote: i thought the KG ones were 6 speed as well?
They made both 5 speed, and 6. ![]() |
Author: | GAT51 [ Mon Sep 24, 2007 9:16 am ] |
I bought out KGs stock and am in the process of making a short run of ten 5 speeds. About half way through and should have some avaialable by the end of the year. KG had both 5 and 6 speeds, but only recommended the 5 speed as the gap between gears was no significant enough to make it worthwhile. |
Author: | TheMiniMan [ Mon Sep 24, 2007 11:33 am ] |
We have the 6 speed KG doggy here & it`s a dam good box, BUT there are some small issues with the hook change from 1st into 2nd being a little slow, our first 6 speed had a little problem with both 5th & 6th gears breaking into 2 pieces on it`s maiden voyage, but it looked like whoever was welding them maybe tack welded them & then went on smoko & forgot to fully weld them before heat treatment ![]() ![]() ![]() I would also like a 5speed doggy tho, that`d go nicely with the turbo injected Bimmer twin cam 16v donk, i`ll keep in touch GAT51, cheers |
Author: | Spaceboy [ Mon Sep 24, 2007 12:03 pm ] |
were they all dog boxes? |
