12g1316 how good is this head https://www.ausmini.com/forums/viewtopic.php?f=2&t=36033 |
Author: | badassmini [ Mon Sep 24, 2007 5:02 pm ] |
Post subject: | 12g1316 how good is this head |
hey guys i have a 12g1316 mini head how good are these heads should i keep it or get a different head. the head will be going onto a pretty hot 1275 so just wont to know if it will stand up to the power cheers dan |
Author: | 1018cc [ Mon Sep 24, 2007 5:15 pm ] |
Its a 1275cc head off the austin america (its a smog head) its also found on the sprite/midget. Pretty comparable to the 12G940 - so either way with either head I would still look at modifying it if its to go on a hot 1275. I don't know how much modification info you will find on the 12G1316 though if you do decide to go with it. Someone else may have more to add about it modification wise though. <edit> Should have said, they have the same size valves as the 12G940 as well. |
Author: | drmini in aust [ Mon Sep 24, 2007 5:31 pm ] |
They are as good as or better than a 12G940, for a high power head. Basically they are just a 12G940 with 4 air holes added to the exhaust porting. Just plug these with 7/16" UNF grubscrews and then treat it like a 940. "They are thicker around the exhaust ports which allows better port shaping to be carried out". So says Vizard, or words to that effect. I've used 2 that have been well modified, no problems. Over here in Oz they were used on the 1275LS, and the late 1275 Mokes. ![]() |
Author: | 1018cc [ Mon Sep 24, 2007 5:34 pm ] |
drmini in aust wrote: Over here in Oz they were used on the 1275LS, and the late 1275 Mokes.
![]() Well there you go. I can say that I learnt something new today! |
Author: | badassmini [ Mon Sep 24, 2007 5:47 pm ] |
sweet cheers that wat i wanted know |
Author: | sox61 [ Mon Sep 24, 2007 6:53 pm ] |
That's good to hear. I just put one on my car and was a little embarrassed to say it was a 'smog' head. ![]() |
Author: | willy [ Mon Sep 24, 2007 6:58 pm ] |
Well if it was a smeg head, it would be a little bit different. |
Author: | sox61 [ Mon Sep 24, 2007 7:04 pm ] |
![]() U gotta love Red Dwarf!! |
Author: | drmini in aust [ Mon Sep 24, 2007 9:56 pm ] |
sox61 wrote: That's good to hear.
I just put one on my car and was a little embarrassed to say it was a 'smog' head. ![]() Well the smallbore `smog' heads were pretty ordinary inside but even those can be ported effectively, you just need to dig more metal out. The 1316 though is pretty good, get Mk2 S valves fitted and spend an hour with a die grinder, it's as good or better than a Mk2 S head. |
Author: | badassmini [ Tue Sep 25, 2007 10:00 am ] |
how far with modifications can you actully go with these heads |
Author: | drmini in aust [ Tue Sep 25, 2007 10:20 am ] |
badassmini wrote: how far with modifications can you actully go with these heads
As far as you can with any 940 head. I have a 1316 on Barney that's got Rimflo inlet valves and Rover unleaded exhaust seats fitted, it's about stage 2. I have another 1316 going on the 1132 Moke that's about the same spec but with stock exhaust seats. I have yet another 1316 for the 1412 stroker that's got MK2 S inlets and big ports, Vizarded by me, it's about stage 3. They also make good race heads, ask GR. ![]() |
Author: | badassmini [ Tue Sep 25, 2007 10:25 am ] |
cool so you can get a fair bit out of them then. |
Author: | sox61 [ Wed Sep 26, 2007 9:59 pm ] |
drmini in aust wrote: Well the smallbore `smog' heads were pretty ordinary
I have another 1316 going on the 1132 Moke that's about the same spec but with stock exhaust seats. Mine is actually a 1316... I previously had a 12G202 which was heavily ported with modified combustion chambers. This head is quite mild compared to the 202 but seems to have achieved the same results as far as power output. Oh, and it's an 1132. ![]() |
Author: | BALLISTIC [ Thu Sep 27, 2007 2:03 am ] |
