wont start no spark https://www.ausmini.com/forums/viewtopic.php?f=2&t=36056 |
Author: | mad-mk1 [ Tue Sep 25, 2007 12:38 am ] |
Post subject: | wont start no spark |
hey gang, got the loom in mad- mk1 and have had a quick play with the motor, to see if i can get it to start. a friend that worked at a mechanic, roughky did the timing, i have power at the coiul, but number 1 theres no spark (with the plug out, on the lead, against the block..) now, theres a wire hanging of my dizzy. where does this go? i looked on the delux, and that wire returns to the coil, but in my loom, there is already wires that go to the coil. any hints tips tricks ideas. cheers jamie |
Author: | awdmoke [ Tue Sep 25, 2007 12:43 am ] |
That wire from the dizzy should be connected to the -ve terminal of the coil. You will never get a spark otherwise. Time to check what those other wires are you've hooked up to the coil ![]() The +ve terminal should have a supply from the ignition switch. |
Author: | mad-mk1 [ Tue Sep 25, 2007 12:47 am ] |
thats wha ti thought, will try it toorrow. on the loom , theres 2 wires, one says +ve coil other says -ve coil thats on teh labels on teh wires from classic wiring looms. hmmm ![]() |
Author: | sports850 [ Tue Sep 25, 2007 6:06 am ] |
Follow the -ve coil wire through and see if it has a loose connector for the distributer wire . |
Author: | aaron [ Tue Sep 25, 2007 7:12 am ] |
your loom will have power to the coil and a tacho feed, hence two wires. As said you need to connect the dissy to the coil to get power to it. ![]() Cheers Aaron |
Author: | CJ_DT [ Tue Sep 25, 2007 8:52 am ] |
The coil ends up with three wires hooked to it normally |
Author: | sgc [ Tue Sep 25, 2007 9:41 am ] |
CJ_DT wrote: The coil ends up with three wires hooked to it normally
.. when you have a tacho fitted. Without a tach, it's only two: +12V from the ignition switch (coil +ve) and the low tension trigger from the points (coil -ve). |
Author: | mad-mk1 [ Tue Sep 25, 2007 9:50 am ] |
sgc wrote: CJ_DT wrote: The coil ends up with three wires hooked to it normally .. when you have a tacho fitted. Without a tach, it's only two: +12V from the ignition switch (coil +ve) and the low tension trigger from the points (coil -ve). thanks heaps guys, as i suspected. cheers jamie |
