dr trim wrote:
hey guys im having some pretty bad problems with my cooling system at the moment.
driving from work to home, in the arvo in about 32 degree heat today and previous days my car gets almost to the H on the old school smiths guage.
What can i do to make my car run cooler?
i have to wait to get paid until the 30th til i can spend any amounts of money over $50, and i only have work for one more day so i can afford having the car off the road for a while.
im thinking of:
replacing thermostat
replacing water pump
flushing radiator
and if all that fails fitting an auxillary radiator (commodore heater core).
Are there more common things than the other? coz if i can isolate the problem without spending money and just spend it on the one thing it would be much better.
any methods to check if stuff is alright without removing everything completely?
i also run a thermo fan and even with that on it really doesnt make a big difference once the temperature rises past 6 o'clock on the guage it seems unstoppable.
i dont have a overflow bottle coz it fell out of its bracket and onto the extractors, so i need to get one of them so i can use coolant again (the coolant has just pissed out of the overflow and has been subsituted by top up tap water)
help
Well for a start, put the coolant back in...it raises the boiling point.
Is the thermo fan blowing into the radiator cowling??
Is the guage reading correctly?.....when you stop....do you see lots of overflow??
replacing thermostat - how old is it? just check its operation....
replacing water pump - why? how old is it?
flushing radiator - well you have been doing that slowly topping up the water!!
and if all that fails fitting an auxillary radiator .....shoudn't need it unless yer engine is highly mortified!!!
Doc.......
