Do Cam Bearings Need to be Reamed? https://www.ausmini.com/forums/viewtopic.php?f=2&t=36131 |
Author: | Anto [ Thu Sep 27, 2007 9:51 am ] |
Post subject: | Do Cam Bearings Need to be Reamed? |
As per title, do new cam bearings generally need to be reamed once fitted? I only ask as I have one new set here that slide perfectly over the cam, and another one that doesn't which is from a different manufacturer but otherwise looks the same. I'm wondering if it is supposed to be reamed or if it is a dud. |
Author: | Wombat [ Thu Sep 27, 2007 11:51 am ] |
There are two sorts on the market - 'non reamable' and 'reamable'. Apparently the non reamable can have sloppy tolerances and you run the risk of vibration moving the bearing. This happened in my engine I'm rebuilding - not with me but previous owner as when I pulled it down the centre bearing was 8mm out of the web and had fouled the push rod. The reamable one can be reamed to a tighter tolerance and you end up with a smoother running cam. A special reamer is used that lines all three up as well. |
Author: | drmini in aust [ Thu Sep 27, 2007 7:10 pm ] |
Most cam bearings that you could buy now from Karcraft and elsewhere for years, are pre-finished. I even had a NOS set in a BMC box that is pre-finished. But you need to be real careful fitting them, or they distort- which is why I pay Graham Russell to fit mine, he has the proper gear. ![]() |
Author: | Mick [ Thu Sep 27, 2007 8:02 pm ] |
By proper gear do you mean the dollies? |
Author: | drmini in aust [ Thu Sep 27, 2007 8:05 pm ] |
If that's what you call them, but I'd call them guide spigots and plates.. ![]() It's easy to bruise and deform them if you try and hit them in without them being guided. I'd make some guides up if I had a bunch of bearings to do. |
Author: | Mick [ Thu Sep 27, 2007 8:08 pm ] |
Yep that paints a picture nicely. Thanks. I've seen guys do it with three spigots (?) machined to fit the inner diameter of the individual bearing with a shoulder machined half way up. Then they were tapped in. Still easy to misalign I guess. |
Author: | drmini in aust [ Thu Sep 27, 2007 8:12 pm ] |
I would put a 16mm hole in all the spigots, then pull them in with a long piece of H/T threaded rod and nuts.. No BFH required. ![]() |
Author: | Mick [ Thu Sep 27, 2007 8:24 pm ] |
You are right, much more elegant. |
