It is currently Sat Jul 19, 2025 7:20 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: wierd engine number.
PostPosted: Mon Sep 24, 2007 5:51 pm
hey guys i have just purchased a 1275 motor but it has a wierd engine number it 12h_c2uhzcc15c3 i think theres a number or letter missing between the h and c can't make out what it is any help.
Cheers Dan
 Post subject: Re: wierd engine number.
PostPosted: Mon Sep 24, 2007 7:12 pm
I think you need to clean it up and have another look. I would almost bet that the "c"s are "0"s.
I would need all the digits in the correct case to get it worked out. (12H not 12h :wink: )
PostPosted: Tue Sep 25, 2007 1:21 pm
sorry. i went and cleaned up the numbers today with a wire wheel and the nunber goes
12HC2UHZCC15C3 the c's are definatly c's not 0's maybe it has been stamped wrong i don't know any ideas.
ill try post a pic of the number and motor later on.
cheers dan
Cheers Dan
PostPosted: Tue Sep 25, 2007 3:11 pm
I looked at a Sprite for sale a while back which has engine number 12HC at the start. It was a 1275, obviously.
PostPosted: Tue Sep 25, 2007 7:53 pm
here you go not a very good pic but you can read it.
[img][img]http://i81.photobucket.com/albums/j211/badassmini/DSC01704.jpg[/img][/img]
Cheers Dan
PostPosted: Tue Sep 25, 2007 8:02 pm
I'm no expert on engine numbers but the H in 12HC should stand for high compression so it should be a good'un
Noli Illegitimi Carborundum
PostPosted: Tue Sep 25, 2007 8:08 pm
I think it's a 1300 Metro engine. But I don't know about anything after 12HC, if that is infact the first 2 letters.
12H is very vague as many 1275 engines either have just that as there prefix or 12H* (where * is another letter).
PostPosted: Tue Sep 25, 2007 8:13 pm
yeah the number goes 12H C theres a space between the H and C.
Cheers Dan
PostPosted: Tue Sep 25, 2007 8:14 pm
my metro 1300 engine is 12hd09, this one could be a different year though.
PostPosted: Tue Sep 25, 2007 8:15 pm
I can't find any 12H*C though, bugger, :( someone should know out there....
PostPosted: Tue Sep 25, 2007 8:16 pm
maybe the c is another 0, that would make sense
wait until the UK dudes chime in... I think it's a Metro donk too. :wink:
Is it an A+, ie dizzy held in with 1 bolt and a finger clamp (just like GM/Ford Chrysler?)
Last edited by drmini in aust on Tue Sep 25, 2007 8:17 pm, edited 1 time in total.
PostPosted: Tue Sep 25, 2007 8:17 pm
if it is a metro motor how good are the metro motors
Cheers Dan
PostPosted: Tue Sep 25, 2007 8:18 pm
sounds like it to me, 1275 A+ motor, made in the 80's and likely low KM's, maybe even unbored.
PostPosted: Tue Sep 25, 2007 8:19 pm
all A+ motors are good. All 1275 A series are good. I run one of each... :wink:
Best Metro one (apart from turbo) was the MG Metro, had 72HP I think with 1 carby.
