Advance https://www.ausmini.com/forums/viewtopic.php?f=2&t=36176 |
Author: | mooman10_0 [ Fri Sep 28, 2007 2:00 pm ] |
Post subject: | Advance |
I have a 1275 motor starting with 12Y, just wondering what the timing should be set at? Thanks, steve |
Author: | Matt68 [ Fri Sep 28, 2007 2:54 pm ] |
Ignition timing? I think a bog stock 12Y/TaH motor would have had a static timing figure around 6 or 7 degrees advance, maybe someone else has access to a manual for the 1100s? In any case, the advance curve can be altered in the dizzy, is it original? Vacuum advance working? What total advance does it give? Best to check these things out. On a modified motor, you decide what you need, and try to achieve it by getting the dizzy modded to suit. M |
Author: | mooman10_0 [ Fri Sep 28, 2007 3:28 pm ] |
Therre is no vacuum advance, was wondering cause the book I have says for 1275 without emmision control 10 or 12 degrees? ![]() |
