Is there a rack to body seal/gasket?? https://www.ausmini.com/forums/viewtopic.php?f=2&t=36202 |
Author: | rampage101 [ Sat Sep 29, 2007 8:39 am ] |
Post subject: | Is there a rack to body seal/gasket?? |
As in the title, should there be a seal where the pinion comes through the body at the firewall? I've just gotta paint the U bolts and the rack can go in. |
Author: | drmini in aust [ Sat Sep 29, 2007 11:22 am ] |
Yes there's a bit of foam goes in there. I used a bit of polyurethane foam 1/4" thick, just cut it out with scissors. |
Author: | rampage101 [ Sat Sep 29, 2007 11:40 am ] |
Thought thats what it might have been. Thanks Dr, as always ![]() |
Author: | GT [ Sat Sep 29, 2007 3:55 pm ] |
If you buy a spindle of CD's or DVD's, you get a round foam type of thing on the top of the spindle, the size of a 20c piece and 1/4 inch thick. Even has the right size hole in the middle of it. PERFECT for what you need. ![]() |
Author: | Wombat [ Sat Sep 29, 2007 4:42 pm ] |
GT wrote: If you buy a spindle of CD's or DVD's, you get a round foam type of thing on the top of the spindle, the size of a 20c piece and 1/4 inch thick. Even has the right size hole in the middle of it.
PERFECT for what you need. ![]() The spindle I have the disc is 1/8" thick ![]() ![]() |
Author: | drmini in aust [ Sat Sep 29, 2007 4:57 pm ] |
Tou want some foam with body in there, not that soft CD crap.... it'll just soak up water, if it doesn't shrink and fall out... ![]() |
Author: | Wombat [ Sat Sep 29, 2007 5:49 pm ] |
The stuff in my CD spindle looks and feels like neoprene - like wet suit material - won't soak up anything ![]() |
