floor plan
https://www.ausmini.com/forums/viewtopic.php?f=2&t=36213
Author:  scolesy [ Sat Sep 29, 2007 2:35 pm ]
Post subject:  floor plan
hi again.
on the floor of my mini inparticular up the front it is starting to rust a bit.
i was wandering if its a good idea to coat the whole floor with K&H underbody protector or should i just use rust converter and prime it :?: .
any suggestions would help :D
Author:  buztoy [ Sat Sep 29, 2007 5:29 pm ]
take to it witha flapper disc and a wire wheel, prime it and fish oil
Author:  GT [ Sat Sep 29, 2007 7:13 pm ]
Post subject:  Re: floor plan
and trap all that nasty rust underneath? :o:o
Try POR Marine Clean, POR Metal Ready, and POR15 Anti Rust Enamel.
A little expensive, but a proven remedy for your problem. I have seen all of the above used together and it's quite amazing really.
Author:  Mister White Keys [ Sat Sep 29, 2007 7:29 pm ]
The only way to get rid of rust is to actually get rid of it. Take to the floor with a wire brush and strip the rusted areas back to bare metal. Then you car treat it appropriately with a number of products.
Covering up rust is a loosing battle. Not only does it not work, you can't see how bad it gets.
Author:  scolesy [ Sun Sep 30, 2007 1:55 pm ]
ok :) , after i bring it back to bare metal do i prime it then fish oil or the other way around.
does anyone know how good K&H rust converter is?
I know these are probly stupid questions but i want to do it right :oops:
Author:  DTrain [ Sun Sep 30, 2007 2:10 pm ]
wire wheel is good for getting rid of surface and flaky rust but for rust thats dug into the metal get the grinder out and grind it out completely. i believe that the rust converters are good but run on the assumption that if theres any rust that you covering (even treated and convered rust) then its more than likely gunna come back in time. i suggest getting rid of all rust completely, welding in new pieces if needed, then hit it with an epoxy primer and go from there with whateva you want to cover it (whether its fish oil or bitumen sealer or whatever)
Author:  GT [ Sun Sep 30, 2007 7:20 pm ]
fish oil is preventative maintenance... not a cure for existing problems.
ONLY apply fish oil over a top coat... not a primer. It will ruin a primer and make top coats resist it, rather than stick to it.
