It is currently Sat Jul 19, 2025 1:09 pm
PostPosted: Mon Oct 01, 2007 8:23 am
Daffodil 1275
Hi all
Which of these two bump stops should i use for a hydro mini
Cheers Phill
KillaWatt Converions
"E"Mini, 144volt, 600 amp, 86kw from the get go
PostPosted: Mon Oct 01, 2007 8:27 am
Those rounded ones have been shaved.
So have mine.... 8) :D
PostPosted: Mon Oct 01, 2007 8:50 am
Daffodil 1275
would i be better of using the shaved ones??? hydro without shocks
Cheers Phill
PostPosted: Mon Oct 01, 2007 8:57 am
If you are going to run it low, yes.
If using stock hydro height, stick with the standard ones.
