GT wrote:
Is this for your Lake Green 'S' ?
I need trim for a Lake Green S too. The one I will be restoring had door cards the same as those shown below, which would mean the seats are different to those you have shown. Body number is 32##, Chassis 37##
Others have said there was a change over date to the trim you have shown, so those seats might be right for your S.
GT , your S is a late 1967 early 1968 going by the numbers . Seats should be the same as those in the ebay pics , and door trims should have the 8 lines , not the rectangles as in your pics . My Lake Green S is late 1967 , around October/November , car number 31## . It has its original door cards and seats
Edit : According to Watto , the Lake Green S had 2 trim colurs , either Green or Beige . Mine has the biege , which is actually called Doeskin , not sure what the Green is called , Brett may know
