It is currently Sun Jul 27, 2025 9:15 am
 Post subject: qu about cooper s discs
PostPosted: Tue Oct 02, 2007 7:03 pm
Do the bolts which hold the flange plate to the rotor itself have the normal clockwise thread pattern? Changing rotors to newbies and the bolts r being un co-operative? :D
thanks, steve
PostPosted: Tue Oct 02, 2007 7:16 pm
The 4 phillips head screws- yes they do. Use an impact driver... :wink:
PostPosted: Tue Oct 02, 2007 7:23 pm
Tried on one side and it just chewed the head, and it was a good philips head piece, the metal just gave way, so will ahve to drill that one, hopefully the others come out better!
PostPosted: Tue Oct 02, 2007 7:51 pm
When you go to get replacements from a bolt supplier, if you take out the rear drum screws, they are the same thread and countersunk head shape, just a little shorter.
You could even get a the longer ones for the spacer drums and cut them down.
PostPosted: Tue Oct 02, 2007 7:52 pm
Or you could go buy some noice Allen head csk screws from a fastener place. :wink:
PostPosted: Tue Oct 02, 2007 8:40 pm
I second that...
