SU overhaul https://www.ausmini.com/forums/viewtopic.php?f=2&t=36329 |
Author: | andywado [ Wed Oct 03, 2007 8:27 am ] |
Post subject: | SU overhaul |
Hi chaps I've got an 1 1/4 SU that I'm planning to overhaul everything seems ok except the spindle. Its pretty loose. what wears out the shaft or the hole and is it expensive to fix? Andy |
Author: | GT [ Wed Oct 03, 2007 8:35 am ] |
I am pretty sure both can / will wear. The shafts in my twin HS2's were worn .020". Classic motoring in the ACT sell rebuild kits that include new shafts. Good value, good kits. http://classicmotoring.net.au |
Author: | 1018cc [ Wed Oct 03, 2007 8:41 am ] |
They both wear. Mine had to be drilled out on the body to the next size and it had larger shafts fitted. I think you can use the standard shafts with a bush to take up the wear but I would only do that as a last resort. They work nice and I would recomend you getting your carb rebuilt (it'll be worth it). |
Author: | Wombat [ Wed Oct 03, 2007 8:42 am ] |
There are a couple of rebuild kits - basic and more extensive. Check that the one you get has the inserts (spindle bearings?) to fit the spindle properly. A bit more fiddly to install as the holes have to be accuratly drilled and aligned but worth the effort. |
Author: | GT [ Wed Oct 03, 2007 8:49 am ] |
I reckon this looks really interesting!! http://www.ausmini.com/forums/viewtopic.php?t=35277 |
Author: | andywado [ Wed Oct 03, 2007 8:58 am ] |
thanks guys. and the bearing idea looks ok as well. |
Author: | d1ck0 [ Wed Oct 03, 2007 9:09 am ] |
Just checked out David's website http://www.minisprintgt.com and looks like he'll be a handy friend to have on here. And if you live in SA he's happy for you to use his workshop quote "AM ALSO OFFERING THE WORK SHOP FACILITIES AND ASSISTANCE IF YOU WISH TO LEARN HOW TO DO VARIOUS JOBS ON YOUR CAR." Cant wait till i'm semi retired....... Dicko |
Author: | AJ [ Wed Oct 03, 2007 9:56 am ] |
Try David Rosenthal in SA , 0429088100 , Ive heard he does a very good job , and for a very reasonable price , $180 , complete overhaul for twin SU's, that includes fitting miniature bearings to the shaft , same as weber has ........ you will never have shaft problems again |
Author: | chopchop [ Wed Oct 03, 2007 10:08 am ] |
$180 is a great price. I was priced min $240 a carb the other day. Got a kit for $116 and am going to give it a go myself now. Be prepared for some questions everyone |
Author: | simon k [ Wed Oct 03, 2007 10:17 am ] |
chopchop wrote: $180 is a great price. I was priced min $240 a carb the other day.
Got a kit for $116 and am going to give it a go myself now. Be prepared for some questions everyone just take your time and get everything spotless.... the choke levers are an odd little setup with a screw, sleeve, spring and some washers, so take some photos, and make notes about what goes where. Also, if you do one carb at a time, you'll have the other one to refer to when you get confused. and one important point, when it comes to removing the bowl from the carb, and the odd shaped rubber that goes between them, DO NOT TWIST IT there is a little locating lug which can and will break if you twist them apart... drilling a hole in each side and aralditing a pin between them isn't a fun job ![]() |
Author: | andywado [ Wed Oct 03, 2007 1:03 pm ] |
Hey fellas bought a new spindle for it. fits like a glove. seems to rev a lot crisper than before. |
Author: | david rosenthal [ Thu Oct 04, 2007 12:27 am ] |
If you are after carby overhaul kits I get mine from Autopro in Gawler. These are Fuel Miser kits [parts from england and packaged here] and are $30-00 for gasket set,jet, fuel bowl needle[ spring type] and seat. Shaft and bushes kit $17-00. butterfly disc and screws kit $8-00 |
Author: | meehal [ Thu Oct 04, 2007 7:35 am ] |
On the topic of this..... Is it recommended to purchase the SU tools from the classicmotoring site? http://classicmotoring.net.au/cmos/inde ... Path=68_74 |
Author: | Wombat [ Thu Oct 04, 2007 11:27 am ] |
meehal wrote: On the topic of this.....
Is it recommended to purchase the SU tools from the classicmotoring site? http://classicmotoring.net.au/cmos/inde ... Path=68_74 I've done 3 without special tools so can't say if having special tools helps - I certainly didn't feel handycapped in anyway ![]() |
Author: | Anto [ Thu Oct 04, 2007 11:28 am ] |
Yes you don't need the tools but they can be helpful. I've never bothered myself as I already have a socket that fits the fuel float valve, which is the main tool you need. |
