Found my first oil leak (with pic) https://www.ausmini.com/forums/viewtopic.php?f=2&t=36365 |
Page 1 of 2 |
Author: | boho [ Thu Oct 04, 2007 10:51 am ] |
Post subject: | Found my first oil leak (with pic) |
Found my first ![]() ![]() Re: poll, please let me know if i could (as a novice) do this job, or if i should get my mech to do it? If i did it, what would i need to get? i.e. What part / seal / thing has actually gone? ![]() Thanx, guys! You rock! ![]() |
Author: | Anto [ Thu Oct 04, 2007 11:21 am ] |
Not too hard to do, will require popping the driveshaft out on one side. The last engine I put in my car developed a big leak out of the O-ring seal on the drivers side diff plate due to the seal not being fitted correctly (my bad), so basically I had to do the same job to replace a different seal. Not too hard, but then I don't know your level of mechanical ability, so I don't want to recommend you dismantle your whole car in the driveway with a screwdriver and then not be able to put it back together. Oh and by the way, the seal that has likely had it is the output shaft seal, about $4 worth. |
Author: | boho [ Thu Oct 04, 2007 11:26 am ] |
Thanx again, Anto. |
Author: | brett [ Thu Oct 04, 2007 11:31 am ] |
when my mini stops leaking oil that usually means I have no Oil left. Saves me checking the dipstick regualry ![]() |
Author: | boho [ Thu Oct 04, 2007 12:04 pm ] |
brett wrote: when my mini stops leaking oil that usually means I have no Oil left. Saves me checking the dipstick regualry
Author: | Anto [ Thu Oct 04, 2007 12:23 pm ] |
I've had a few engines that I let fall to 600ml below minimum and then topped up to the minimum mark, burnt less oil that way and still ran fine - wide tolerances ![]() |
Author: | sports850 [ Thu Oct 04, 2007 1:12 pm ] |
It's a reasonably big job beacuse you have to split the balljoints to get the hub out of the way enough to get the driveshaft out but it's a straightforward job and you shouldn't have too many problems with it . Give it a go , get your dainty hands dirty and you might enjoy it ![]() |
Author: | boho [ Thu Oct 04, 2007 1:46 pm ] |
Ok. In discussion with dad, we've decided not to try it, just in case we damage something. ![]() Have booked in with my mech for Tuesday. ![]() ![]() |
Author: | sports850 [ Thu Oct 04, 2007 1:54 pm ] |
Diff seal to suit pot joint's , anyone with mini experience will know what you need . |
Author: | slinkey inc [ Thu Oct 04, 2007 1:54 pm ] |
First oil leak...Pfft. If there's no oil leaks from my car I get worried that there's none left. ![]() |
Author: | boho [ Thu Oct 04, 2007 1:59 pm ] |
sports850 wrote: Diff seal to suit pot joint's , anyone with mini experience will know what you need . Thanx, Ian. Is it a different size for a 1275? slinkey inc wrote: First oil leak...Pfft.
If there's no oil leaks from my car I get worried that there's none left. I know! ![]() ![]() EDIT: Thanks to mad-mk1 for his useful and informative input into this thread. ![]() |
Author: | sports850 [ Thu Oct 04, 2007 2:11 pm ] |
Nope , all pot joints were the same . |
Author: | boho [ Thu Oct 04, 2007 2:13 pm ] |
Thankyou, Ian. Apologies for my ignorance. |
Author: | sports850 [ Thu Oct 04, 2007 2:17 pm ] |
No worries , now stop being a wimp and pull your mini apart . Drive up here and I'll give you a hand ![]() |
Author: | mad-mk1 [ Thu Oct 04, 2007 2:17 pm ] |
BohoMini wrote: EDIT: Thanks to mad-mk1 for his useful and informative input into this thread. ![]() u must ahve been fairly looking. that post was deleated like teh instant i put it up, because it was worthless. |
