Hi Matt,
Ezy-outs should be banned from the market, they cause more problems than they ever save. The problem here is that the Ezy-Out expanded the broken part of the fitting and it is now twice as tight as it was. They are extremely hard and you may need professional help to remove it. The options might be to drill the wall of the broken fitting and try to collapse it or have the broken Ezy-Out spark eroded out by a machine shop. If you don't have much ability, talk to someone in the trade, maybe an engine reconditioner.
Regards
Al
