It is currently Fri Jul 25, 2025 11:37 pm
PostPosted: Thu Oct 04, 2007 10:51 am
I want to have Al's babies
Found my first ;) oil leak this morning. Looks like the seal in the driver's side drive shaft (see pic). :(
Re: poll, please let me know if i could (as a novice) do this job, or if i should get my mech to do it?
If i did it, what would i need to get? i.e. What part / seal / thing has actually gone?
Thanx, guys! You rock! :D
PostPosted: Thu Oct 04, 2007 11:21 am
Not too hard to do, will require popping the driveshaft out on one side. The last engine I put in my car developed a big leak out of the O-ring seal on the drivers side diff plate due to the seal not being fitted correctly (my bad), so basically I had to do the same job to replace a different seal. Not too hard, but then I don't know your level of mechanical ability, so I don't want to recommend you dismantle your whole car in the driveway with a screwdriver and then not be able to put it back together.
Oh and by the way, the seal that has likely had it is the output shaft seal, about $4 worth.
PostPosted: Thu Oct 04, 2007 11:26 am
Thanx again, Anto.
PostPosted: Thu Oct 04, 2007 11:31 am
when my mini stops leaking oil that usually means I have no Oil left. Saves me checking the dipstick regualry :lol:
PostPosted: Thu Oct 04, 2007 12:04 pm
:shock: You kidding?! Mine starts to crap itself when it's lost 200ml! (Runs on, gets freakin hot, etc. :shock:
PostPosted: Thu Oct 04, 2007 12:23 pm
I've had a few engines that I let fall to 600ml below minimum and then topped up to the minimum mark, burnt less oil that way and still ran fine - wide tolerances 8)
PostPosted: Thu Oct 04, 2007 1:12 pm
It's a reasonably big job beacuse you have to split the balljoints to get the hub out of the way enough to get the driveshaft out but it's a straightforward job and you shouldn't have too many problems with it . Give it a go , get your dainty hands dirty and you might enjoy it :P
PostPosted: Thu Oct 04, 2007 1:46 pm
Ok. In discussion with dad, we've decided not to try it, just in case we damage something. :?
Have booked in with my mech for Tuesday.
:?: Next (and hopefully final Q), what exact seal is it that we think has gone and where can i get it? Also, is the seal the same from Rover to Morris (i've got a Morris dealer just round the corner. ;))
PostPosted: Thu Oct 04, 2007 1:54 pm
Diff seal to suit pot joint's , anyone with mini experience will know what you need .
First oil leak...Pfft.
If there's no oil leaks from my car I get worried that there's none left. :lol:
PostPosted: Thu Oct 04, 2007 1:59 pm
Thanx, Ian.
Is it a different size for a 1275?
I know! :D It's great. :twisted:
EDIT: Thanks to mad-mk1 for his useful and informative input into this thread. :roll:
PostPosted: Thu Oct 04, 2007 2:11 pm
Nope , all pot joints were the same .
PostPosted: Thu Oct 04, 2007 2:13 pm
Thankyou, Ian. Apologies for my ignorance.
PostPosted: Thu Oct 04, 2007 2:17 pm
No worries , now stop being a wimp and pull your mini apart . Drive up here and I'll give you a hand :P
u must ahve been fairly looking.
that post was deleated like teh instant i put it up, because it was worthless.
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
