Mk1 Sliding window felt channels
https://www.ausmini.com/forums/viewtopic.php?f=2&t=36473
Author:  66S [ Mon Oct 08, 2007 11:25 am ]
Post subject:  Mk1 Sliding window felt channels
Hi guys,
I need some lower felt sliding window channels for the 850 I'm working on. Who would you recommend in Oz for quality parts and service?
Regards
Al
Author:  Mister White Keys [ Mon Oct 08, 2007 3:58 pm ]
Al
I would highly recommend Brenton at A Grade Classic Parts for the parts you need. He is extrememely well priced, friendly and will do a great deal for you in postage as well.
Ph. (03) 57 801 300
Fax. (03) 57 801 311
http://www.agradepanels.com.au
Author:  GT [ Mon Oct 08, 2007 4:08 pm ]
Karcraft or Heritage MG (Mini) will probably be the cheapest for those.
www.karcraft.com.au or www.mgspareparts.com.au
Author:  1071 [ Mon Oct 08, 2007 8:26 pm ]
Be a bit careful. You can still get the rigid bottom channel but the only upper piece available seems to be rolls of similar shaped rubber. These fit quite well when new but shrink after a couple of years. When this happens the windows will more or less sieze up.
If anyone knows where to get the proper metal stiffened channel I'd really appreciate the advice.
Cheers, Ian
Author:  drmini in aust [ Mon Oct 08, 2007 11:00 pm ]
Karcraft lists 2 versions of that top channel, soft and hard...
Author:  66S [ Tue Oct 09, 2007 6:10 am ]
Thanks guys, I've banged them all an e-mail, so we'll see what happens. MiniSpares are out of them and many suppliers are waiting on fresh stock.
Regards
Al
Author:  cush [ Tue Oct 09, 2007 9:16 am ]
i got mine from brickworx here in sa....
just another option... ;)
Author:  marcello [ Tue Oct 09, 2007 9:36 am ]
a while ago i went into clark rubber and asked if they had any of the top window stuff. the guy i asked was young and had no idea. it was not in the catalog so he said they didnt have it. i went back again and asked another guy weeks later who was much nicer and seemed to know more. he called up the sydney office and managed to track down some of the metal reinforced stuff for me. it was exactly as the original item. a few days later it arrived. cost about 170 bucks for a cars worth. it is perfect. all the dimensions are as original and the look is the same too. give them a try, go in with an original sample.
Author:  66S [ Tue Oct 09, 2007 10:26 am ]
Thanks for the help guys, I've got a pair coming from Brenton. They are the only 2 he had and genuine parts from the 1980's.
Regards
Al
Author:  66S [ Thu Nov 08, 2007 8:36 am ]
Mister White Keys wrote:
Al
Ph. (03) 57 801 300
Well guys,
I got the channels from Brenton (posted promptly), but when fitted, there was a problem with the quality of one. Brenton had advised it was slightly different to the other but we both thought it would do the job. Unfortunately, it wouldn't and I want to let you all know Brenton stood behind it totally and without an argument. He is to be recommended as a reliable supplier and I hope he does plenty of profitable business because of his attitude. I thought you should all know!
Regards
Al
