Fitment of KAD Quickshift to Remote Box
https://www.ausmini.com/forums/viewtopic.php?f=2&t=3650
Author:  sg [ Sun Dec 26, 2004 1:21 pm ]
Post subject:  Fitment of KAD Quickshift to Remote Box
Guys, can anyone here give me a rundown on the method of fitting one???
I tried to fit one to Slidey (MK1 remote box) this morning, following the instructions, yet when i completed to job this is what i found......
1. I couldn't get the black bush to fit all the way into the locating hole at the bottom
2. When i tried to select gears, i found that i could only select 2nd, 4th and reverse. Upon trying to select 1st and 3rd it seemed that the gearstick was butting up against something or was at the end of it's throw, yet i was still in neutral. I am i missing something in the original box? or have i not fitted correctly............
Any ideas or solutions???????? I am kind of lost. :oops: :cry: :?
Author:  drmini in aust [ Sun Dec 26, 2004 7:05 pm ]
PM Boostedmini, he is running one.
Got my reverse lockout spring fitted yet? :P
Author:  sg [ Sun Dec 26, 2004 7:08 pm ]
When i failed miserably with the KAD kit, i fitted that instead Doc :D
Author:  tzi [ Sun Dec 26, 2004 11:22 pm ]
what is it :?: :?: :?: :?: :?
Author:  drmini in aust [ Mon Dec 27, 2004 6:17 am ]
Tzi, see in here-
http://ausmini.tziworld.com/viewtopic.php?t=3544
8)
Author:  dr trim [ Tue Dec 28, 2004 12:25 pm ]
where do i get one kev? is it just a simple spring?
Author:  drmini in aust [ Tue Dec 28, 2004 6:18 pm ]
I've got none left- Aaron got my last one...!
As I said in the other thread, They are a 3/8" (OD) x 3" long BLUE die spring, cut in half with an angle grinder & the end ground flat. Finished length is 1-1/2" (38mm). So, you get 2 out of a standard spring. :wink:
These springs are sold by Automatic Springs (John While) in Sydney. Any toolroom would have them or could get. 8)
Author:  tzi [ Tue Dec 28, 2004 10:20 pm ]
:oops: um ok.. so I guess thats the spring that was on the floor after finishing the engine swap :oops:
just finished swapping my engine today.
had a spare engine with remote shifter gearbox, to go into my clubby ( rod change)
couldnt figure out how to change the CV's so we removed the entire box off both engines and swapped them over :roll:
on the plus side... I got to keep my rod change... synchro on all gears!! BLISS :D
anyway.... this spring... where does it go, and how to I put it back???
photos anyone?? :?
Author:  drmini in aust [ Wed Dec 29, 2004 6:12 am ]
This spring is only used on remote or 850 boxes, 3 & 4 synchro, but not rod change.
It goes below the reverse switch (or hex plug) on the front of the box. (Below oil filter).
Not something that normally gets taken out when box is stripped so I doubt it's rolling around on the floor! :lol:
