It is currently Sun Aug 17, 2025 1:36 am
 Post subject: Radiator shroud
PostPosted: Tue Oct 09, 2007 10:25 pm
Hi I was replacing the thermostat, I pulled of the radiator top bracket as you have to ...put it all back together...and what do you know the shroud is scrapping on the fan. There is a missing nut in the middle of the radiator at the back where the 2 pieces meet but of course you cant get in there to do anything. Any suggestions?..... :roll:
Thanks in advance
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
PostPosted: Tue Oct 09, 2007 10:56 pm
They are made of thin sheet metal, you may have bent it when forcing it back in. Try removing it or simply rebending it as best you can in situ.
 Post subject: Re: Radiator shroud
PostPosted: Wed Oct 10, 2007 7:09 am
Monster Mini wrote:
..... of course you cant get in there to do anything. Any suggestions?..... :roll:
Perseverance. It's a self-tapping screw with a small hex head. You can replace it in situ with a small spanner, skinned knuckles and lots of patience.
Curly
