It is currently Sat Jul 26, 2025 6:15 pm
PostPosted: Thu Oct 11, 2007 5:46 pm
is it possible to cut around the seem of one lh tank and attache to the back of another petrol tank? drill a hole in the top and bottom of it so fuel and air can pass easily between them but leave the wall to stop the momentum of the fuel rocking around so much.
has anyone done anything like this before?
what are the legal implications? would it need to be engineered certificated?
how hard is it to weld a hole free seem and grind it back flush?
(i'd appreciate it if no-one pointed out the fact you have to make sure there is no petrol vapour in either tank before you start cutting and welding. thank you)
PostPosted: Thu Oct 11, 2007 5:52 pm
i was about to cut up a l/h tank and make it into a r/h tank, it seems like it will fit but the reason why i didn't is that i think rust will inhibit the welds where you have welded the tank up
Actually I've got to point out just how careful you have to be about welding a fuel tank , it's not just the vapour you can smell , most workplaces will insist on the tank being cleaned inside with a steam cleaner till it's too hot to touch the tank and then 5 minutes more . You only get one chance when welding a bomb so be careful .
I have seen people cut an inch or so on the right hand side of the seam (looking from outside the boot) and weld a piece of sheet steel bent into the shape of the tank to enlarge it but considering the amount of Rover tanks about it's just easier to buy one of them .
PostPosted: Thu Oct 11, 2007 5:59 pm
My thoughts exactly
PostPosted: Thu Oct 11, 2007 6:16 pm
I want to have Al's babies
Oh, andbat, you have to make sure there is no petrol vapour in either tank before you start cutting and welding.
Sorry, couldn't resist. :P
i was told when cutting up old fuel drums to fill them with water,
PostPosted: Thu Oct 11, 2007 6:22 pm
it seems most 35L tanks are selling for $150 with $50 postage. i guess it's not that bad. but i was just wondering. i'll keep looking on ebay for one though.
oh an if anyone has one lying around let me know. :)
edit: i've got 2 LH tanks lying around not doing anything is all.
PostPosted: Thu Oct 11, 2007 7:06 pm
:shock:
too bad shipping from here is to expensive, i would be rich :wink:
Rover 214 atm ....
PostPosted: Thu Oct 11, 2007 7:55 pm
I'll sell you a rusty inside one for $50
get some por 15 tank cleaner and your on your way
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Thu Oct 11, 2007 8:02 pm
pm sent :?
PostPosted: Thu Oct 11, 2007 10:04 pm
Wow, I paid that for a RH tank a few years ago....
I must say though, it's hard to put a price on knowing you will make it to where you want to go because you have enough fuel. So in that regard it's probably very worth it!
PostPosted: Thu Oct 11, 2007 10:32 pm
im happy with my rover tank, it was easily worth the price.
PostPosted: Fri Oct 12, 2007 12:19 am
my plastic gerry can cost me $10, with no postage, so unless it is raining when i run out i guess i win, also i like the excuse to stop on a long drive because if i don't i fall asleep :( , bad habit i know
Daniel the concreter (for now)
1974 mini 1100, fully sick rims, disk brakes, new paint, air conditioning, cruise control,v-tech... wishful thinking
PostPosted: Fri Oct 12, 2007 10:24 am
Yeah I got one of those 10L plastic jerry cans in the back too, fits in really nicely on my boot board. Gives me 60L of fuel, good for Hay trips and such.
