It is currently Fri Jul 18, 2025 1:43 pm
 Post subject: Ignition Timing Problem?
PostPosted: Mon Dec 27, 2004 11:05 am
Hi All,
I've just got a quick question about ignition timing; I have just swaped the engine in my mini and I'm now trying to get it started. I'm trying to follow the instrutions in the manual bit I'm a little confised, it says to turn the
engine over until no 1 piston is at TDC and to do this you can take the
rocker cover off and wait until cylinder 4's inlet valve just opens, you
then move the engine a little futher until you can see 9deg on the fly
wheel, then manual then says that the distributer rotor shoud be pointing
towards no 1 spark plug segment in the distibutor but in mine it points
toward spark plug number 4 I'm 180 deg out but every thing is set up the same as my old engine.
Does any one have any idea what I've done? Is there a better way to set the timing?
I was very careful to put the distrubutor back on the way it came off the other engine and also get the ht
leads back the right way.
Brian..
PostPosted: Mon Dec 27, 2004 11:24 am
perhaps someone swaped the leads over after putting the old one back together 180 degs out??
PostPosted: Mon Dec 27, 2004 11:29 am
It is possible that the Dizzy Drive shaft ahs been fitted 180 degrees out of alignment.
Check with the manual to see if the offset in in the correct position when on TDC.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Mon Dec 27, 2004 11:31 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
have you removed the spark plug to make sure the piston is tdc ???
makka
PostPosted: Mon Dec 27, 2004 11:37 am
one has to be tdc if 4 is rocking, and timing chain is right
PostPosted: Mon Dec 27, 2004 11:41 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
there ya go danidad you answerd the problem as to why you look for tdc on 1
makka
PostPosted: Mon Dec 27, 2004 11:43 am
too right makka i wasnt thinking about the timing chain being out b4 so assumed it was a dizzy thing. the timing chain comment was an afterthought edited on after LOL
PostPosted: Mon Dec 27, 2004 11:48 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i put a brand new chain on one of my motors 4 weeks later i cheaked and guess what it jumped 3 cogs
makka
PostPosted: Mon Dec 27, 2004 12:16 pm
Thanks for the posts looks like you have all put me on the right track.
I have just put the dissy back on the old engine and with both engines in the same position(TDC) the rotor is 180deg out, About 2 oclock for the new and about 7 oclock for the old engine. So it looks like the dissy drive is out on one of the engines.
The question is, to fix my problem can I swap the HT leeds from cylinder 1 to 4 and 4 to 1, 2 to 3 and 3 to 2?
Brian
PostPosted: Mon Dec 27, 2004 12:21 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
ke??
no two motors are exactly the same cam degree and other factors must be taken into account ok easy way to do bring one up to tdc make sure the rockers are flat over 1 insert the dissy line it up and go from there ok i also looked at what you said bout swaping the leads you can do tjhis
makka
PostPosted: Mon Dec 27, 2004 12:30 pm
So you new engine has the dizzy drive shaft in the block in 180 degres out of phase and then you need to pull out the shaft and trune it around 180 degrees. Make sure when you pull out the shaft that you have a bolt screwed into the end of it so that when you refit it, it does not drop into the bottome of the engine. If so it means a part strip down and start again.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Tue Dec 28, 2004 1:52 pm
Engine No Start.
I swapped the ht leeds around and reset the timing, I now think I've got the timing and the ht leeds right, but the engine still will not start.
I've checked i'm getting a good spark, fuel is getting to the carby's and battery is charged.
What should I check next? as the engine does not even sound close to starting. Could I have damaged the engine by trying to start it with the ht leeds the wrong way around?
Brian
PostPosted: Tue Dec 28, 2004 8:35 pm
Brian,
Ring me on Bungendore 6236 9419.
Kev.
I solved the same problem for Simon with his new 1300 engine from the UK. I find hands-on is the best approach. Ring now!
I'm a G-force Junkie!!!....that suffers labyrinthitus!!
 Post subject: Welcome Kev
PostPosted: Tue Dec 28, 2004 9:45 pm
Conrod wrote:
Brian,
Kev.
Cheers Kev....once the engine fires into life....get Brian to join the ACT Mini CC!! (out of gratitude!! :lol: )
All the Best, Mick
Users browsing this forum: Bing [Bot] and 105 guests
