It is currently Mon Jul 21, 2025 5:57 am
 Post subject: differences in racks
PostPosted: Thu Oct 11, 2007 12:11 am
I've got a bit of a steering rack obsession going at the moment, I pulled the rack out of a clubman tonight, it was very very sloppy....
taking it apart, I found a home-made looking spacer between the shoulder of the inner race of the outmost pinion bearing, and the plate that goes over it. This is wierd, because all the others I've pulled apart haven't had any spacer, and the outer race is hard up against the outer race... I checked everything against another (ex. deluxe) rack and eventually found that the body where the pinion goes on the rack from the clubman is about 5mm longer than the deluxe rack... but the bearings and pinion and everything else in it was the same, even the casting number on the body. Hence the need for a bodgy spacer. The clubman rack has been rebuilt at some point, and I'm assuming they used the wrong bearings, or something...
I'm going to ditch the body from the rack out of the clubman and rebuild the deluxe one and put it in, but can anyone shed light on the differences?
PostPosted: Thu Oct 11, 2007 12:38 am
Moke Rack?
Mokes had steering lock restricted when they went to 13" wheels.
Bit of swapping been going on?
Sir Alec! we are not worthy!
PostPosted: Thu Oct 11, 2007 7:26 pm
I am currently running the rack out of Spiro da 1968 (big wheel) Moke, in HaHa da 1970 `Matic. 8)
Turns lock to lock is the same, go figure... :shock:
 Post subject: OEM
PostPosted: Thu Oct 11, 2007 8:46 pm
Is it the original rack Doc :?: Does it have the ears :?:
 Post subject: Re: OEM
PostPosted: Thu Oct 11, 2007 9:39 pm
What ears...? :oops: come to think of it I guess it's not original, as I can see farmer Spiro cut the subby with oxy to remove the rack :shock: .
PostPosted: Thu Oct 11, 2007 11:12 pm
the length of the rack is the same... just the part of the body that the pinion goes through is longer taller - it's wierd - but we have someone on the case :)
PostPosted: Sat Oct 13, 2007 10:27 am
Yeah I meant the 13" lock stops..(internal)..off early model BMC Mokes.
Users browsing this forum: No registered users and 118 guests
