It is currently Tue Jul 22, 2025 2:56 am
 Post subject: Petrol tank..
PostPosted: Sat Oct 13, 2007 11:38 am
Has anyone had a larger petrol tank made to suit a Mini? ie: Flat or round tank in boot.
I know I could buy a RH tank or a 35ltr tank but they are either expensive or like hens teeth...
PostPosted: Sat Oct 13, 2007 11:44 am
I want to have Al's babies
Call me crazy, but i remember seeing a picture on here of someone mounting an LPG gas tank on the back wall of the boot (behind the seats).
If THAT was to be done for a petrol tank, you'd be laughing. :D
EDIT: Found it! :D http://www.ausmini.com/forums/viewtopic.php?t=32435
 Post subject: re tank
PostPosted: Sat Oct 13, 2007 11:49 am
to get one made properly would be prohibitably expensive as the welds have to be burst proof,the left hand ones are readily availiable at fairly reasonable prices,and rh ones are through the roof now in price however they are still cheaper than the ones availiable from pommy land.
 Post subject: tank
PostPosted: Sat Oct 13, 2007 12:30 pm
I had an early model holden tank in a mini many years ago.
It was flatand fitted inside the subframe.
Not sure if it would fit under the raer seat, as mine was removed.
You would also need to relocate the battery as well.
PostPosted: Sat Oct 13, 2007 5:13 pm
I had a nice Alloy one in my Sports Sedan. It sat in the bottom of the boot and was fed from the usual filler neck spot.
Wished I'd kept my Sports Sedan, although it was de-seamed and they wouldn't let me run it anymore.
Dicko.
