Removing Clutch https://www.ausmini.com/forums/viewtopic.php?f=2&t=36680 |
Page 1 of 2 |
Author: | Asha [ Sat Oct 13, 2007 2:42 pm ] |
Post subject: | Removing Clutch |
Hey All, Dad and I are trying to take the clutch out of my clubby. We are up to when you take the fly wheel out, have already taken the bolt off. We can't get the fly wheel out though. Is there a trick to it? or is it meant to just wiggle out? Thanks, Ash |
Author: | boho [ Sat Oct 13, 2007 2:43 pm ] |
Don't you need a flywheel puller? |
Author: | Asha [ Sat Oct 13, 2007 2:45 pm ] |
Aww we don't have one of those! Damn. |
Author: | boho [ Sat Oct 13, 2007 2:46 pm ] |
There might be a How To DIY i think. EDIT: Nope. My bad. Someone local should have one. |
Author: | Asha [ Sat Oct 13, 2007 2:55 pm ] |
Rightio, well if anyone has a DYI idea can they let me know? I'll have to source a local one otherwise. |
Author: | sports850 [ Sat Oct 13, 2007 3:00 pm ] |
Beg/borrow/buy/make one if you can as it's the safest way to do it , you can gently tap it off through the starter hole with a piece of wood , turning the carank 90 degrees each time but only do that when you can't get a hold of a puller . |
Author: | Asha [ Sat Oct 13, 2007 3:02 pm ] |
So if I'm not putting it back on, since i'm replacing it, would the tapping option be good or will it damage something else? |
Author: | sports850 [ Sat Oct 13, 2007 3:05 pm ] |
You'll be putting the bit you're tapping (flywheel) back on I assume , also as mentioned by someone else last time I described it you will be putting forces onto the thrust washers inside the motor which could contribute to a later failure . |
Author: | Asha [ Sat Oct 13, 2007 3:08 pm ] |
I see, well i'm replacing the entire clutch I think. Dad seems to think he can get it off without breaking anything. He's the mechanic so I'll trust him with it. Has anyone got a pic or template of a fly wheel puller? |
Author: | Asha [ Sat Oct 13, 2007 3:16 pm ] |
Another question from dad, is the end of the crankshaft tapered? |
Author: | sports850 [ Sat Oct 13, 2007 3:22 pm ] |
Yes the end of the crank is tapered . There is a flywheel puller how to somewhere by the doc , I'll find it and post it here . |
Author: | Asha [ Sat Oct 13, 2007 3:23 pm ] |
Thanks Sport850. |
Author: | boho [ Sat Oct 13, 2007 3:23 pm ] |
Stick it in the How To's, Ian. ![]() |
Author: | sports850 [ Sat Oct 13, 2007 3:24 pm ] |
BohoMini wrote: There might be a How To DIY i think.
EDIT: Nope. My bad. Someone local should have one. Een needs new glasses .... http://www.ausmini.com/forums/viewtopic.php?t=12888 Een , it already is in the how to's ![]() |
Author: | boho [ Sat Oct 13, 2007 3:25 pm ] |
I've done that TWICE in two days! ![]() Sorry to stuff you round, Ash. ![]() |
