It is currently Sun Jul 20, 2025 4:03 pm
 Post subject: Supercharger vs Turbo
PostPosted: Sat Oct 13, 2007 7:17 pm
Hey i have a 1100cc Standard mini and im tossing up between a turbo and a supercharger. I was thinking my car doesnt rev high so a supercharger would be better. Am i thinking right? Piping etc. is no issue i can make up any kind of piping that i need but yeh im just unsure and wanted to see what you guys thought.
PostPosted: Sat Oct 13, 2007 7:29 pm
You will get more serious grunt with a turbo. :wink:
Benjamin has over 102HP ATW from his 1152 turbo on a Dyno Dynamics dyno, and he's not finished yet. 8)
Last edited by drmini in aust on Sat Oct 13, 2007 7:31 pm, edited 1 time in total.
http://www.ausmini.com/forums/viewtopic ... ger++turbo
PostPosted: Sat Oct 13, 2007 10:59 pm
I don't really find that a direct comparo of supercharger vs. turbo is all that fair. But is a good comparison for decided what you want/need.
Yes a turbo in most cases will get you more grunt, and more tune-able and adjustable grunt at that. So for power this is probably the best way. Your sweet spot will be mid range to high rpm, depending on the turbo and manifolds chosen.
The supercharger although doing the same job, cramming more air into the motor, goes about the idea quite a bit differently.
After doing my car I'm leaning towards turbo as the best option. However, the bottom end and mid range can't be beat and the simplicity and cheapness is definitely a bonus when using 'chargers. A heavily worked supercharged beast is going to make alot of power and a lot of torque (gearboxes...look out!), as long as the 'charger size and type is chosen wisely.
The main problem with 'chargers is efficiency. They are just not good at making high boost - they, generally speaking, make a lot of heat. But if your keeping the boost to a sensible road-car level, I see no problem with going eitherway. The car will be fun and fast anyways.
It's up to you completely, go to www.turbominis.co.uk and have a browse, however i must say they are very biased on there, even though many users have superchargerd cars they will ALWAYS suggest turbo as the best option.
PostPosted: Sat Oct 13, 2007 11:23 pm
Good links Spaceboy, interesting quick reads.
PostPosted: Sat Oct 13, 2007 11:54 pm
what i remember from vizard, just info no opion (although i like superchargers more)
turbos use energy from the exhaust an in this process a bit of it escapes as the exhausts moves around the turbine, also some of it may be lost ith low off valves where energy has gone into compressing the air and then it is just waisted.
superchargers however run of the belt drive and don't loose so much energy but more power is needed to turn them. all the air they compress however goes into the cylinder and not out a blow off valve.
PostPosted: Sun Oct 14, 2007 3:20 am
a supercharger will give you all you need from a mini, trust me!
going for a turbo is just for the psshhht from the bov. :D
PostPosted: Sun Oct 14, 2007 5:58 am
That would only be on a blow through carby set up would it not?
Dicko.
PostPosted: Sun Oct 14, 2007 8:00 am
Mien
Any turbo will make that sound. Whether it be from the wastegate, BOV or from compressor stall though is another matter.
PostPosted: Sun Oct 14, 2007 9:59 am
OK thanks. Im still undecided. im leaning towards a supercharger just because i like the idea of setting the supercharger to boost from idle to 5500-6000 rpm. What kinda rpm would a turbo kick in? because if it kicked in at 3000rpm then i would maybe think bout a turbo but anything higher then that i dnt think its worth it in my car. And why im asking questions should my 1100cc stock engine rev higher then 5500rpm?
PostPosted: Sun Oct 14, 2007 10:15 am
i reckon supercharger is the way to go, they just don't seem so ricey are more sophisticated.
if you need more convinceing watch mad max 1 & 2. the black car has an awesome supercharger in it.
(anyone know what car that is?)
some-one did a mini version on here, i'll search for the photo.
edit
edit 2: yeah it's about the power not the look, but you gotta admit it is cool
PostPosted: Sun Oct 14, 2007 12:39 pm
Twas a Falcon Coupe. The only issue I have is with the electronic clutch on the Blower. :roll: This just goes against how superchargers work, but heh, its all make believe anyway isnt it? :D
EDIT - Didn't want to look stupid any more :D
PostPosted: Sun Oct 14, 2007 1:57 pm
Actualy The car started life as a standard 1973 XB GT Ford Falcon Coupe
PostPosted: Sun Oct 14, 2007 1:59 pm
Of course...why on earth did i say hatchback :shock:
Not enough sleep, got up and watched the poms beat France.
PostPosted: Sun Oct 14, 2007 3:42 pm
my supercharger has an electronic clutch, its wired through a relay to be on when the ignition is, but i could put it through a switch..
but then i'd have to have a bypass as the supercharger creates a restriction in the intake if its not moving.
I had to drive it like that when the belt broke..
Users browsing this forum: Bing [Bot] and 61 guests
