It is currently Sun Jul 20, 2025 10:28 pm
PostPosted: Sun Oct 14, 2007 8:00 am
Hi all. I want to install my roof lining today and was wondering wich glue is the best suited fort that, and where can i get it.
Thanks
PostPosted: Sun Oct 14, 2007 8:09 am
3m brand super 74, i get it from a place in port melbourne (cant even remember the name) but what you need to buy is good contact adhesive, and as far as good ones in a can i think this is the best one you can get.
try specialised craft shops, its about $25 per can (the cans last for ages)
PostPosted: Sun Oct 14, 2007 8:16 am
Thanks for that, i assume this will be good for the carpet as well?
PostPosted: Sun Oct 14, 2007 8:18 am
I used Selleys Gel-Grip, it is thicker than most so doesn't run on vertical surfaces.
I use it for the carpet too. :wink:
PostPosted: Sun Oct 14, 2007 8:38 am
Just dont use quick grip like I did once,,it tends to 'melt' roof linings :(
PostPosted: Sun Oct 14, 2007 11:02 am
yep good for carpet too
 Post subject: Glue
PostPosted: Sun Oct 14, 2007 12:05 pm
I used qwik grip on both my roof lining and carpet also door cards and it works great.
Steve
Classic Not Plastic
PostPosted: Sun Oct 14, 2007 6:46 pm
dont use the cheaper spray contacts, they tend to let go, as i found out on my dash. i forget the brand but i bought the same brand in the tin(brush on) and that works perfect. so personally i would steer clear of spray on contact all together. but that 3m stuff looks ok :)
I have a problem.. apparently
PostPosted: Sun Oct 14, 2007 7:12 pm
Oh yeah, cheap contact cement makes baby Jesus cry.
If you get a tin of good brand contact cement, you can thin it down with turps to make it work better if you want to brush it on a piece of trim (like when making the vinyl trims around the car).
PostPosted: Sun Oct 14, 2007 8:57 pm
Thanks all for your help, i used Selleys Gel-Grip works verry well, mayby too well. I stuck the roof lining to the outher of the car, forgot to allow space for the window seal. The roof lining is nice and wrinkle free,...But i Will have to do it again....I will learn :oops: sometime
PostPosted: Sun Oct 14, 2007 9:10 pm
how do you mean? i stuck mine on the outside, and its fine... got a pic? i could be thinking of something else
PostPosted: Sun Oct 14, 2007 9:30 pm
it should still fit on, just press it on harder
PostPosted: Sun Oct 14, 2007 9:40 pm
Thanks for that. Getting the thing is quite a !@#!@#!@ job. Now it's looking good i dont really want to do it again. I will try to push it in
Users browsing this forum: Bing [Bot] and 68 guests
