mini rear panel van door rubbers? https://www.ausmini.com/forums/viewtopic.php?f=2&t=36770 |
Author: | yeehaa [ Mon Oct 15, 2007 7:22 pm ] |
Post subject: | mini rear panel van door rubbers? |
i have a set of mini rear door rubbers and i cant seem to fit them properly with the clips could someone tell me how to fit them properly they are the reproduction ones otherwise i will just silicone them on the rear doors ![]() cheers damian |
Author: | Mister White Keys [ Tue Oct 16, 2007 5:37 pm ] |
Can't really help with the clips issue, but I just stuck mine on with silicone. I did them bit by bit, holding them with clamps as I went until the silicone had dried. Hope that helps |
Author: | yeehaa [ Tue Oct 16, 2007 8:14 pm ] |
ok thankyou for the help cheers damian |
Author: | michaelb [ Tue Oct 16, 2007 11:53 pm ] |
Hi, Try contact cement, its much quicker than silicone. Clips usually fit into a slot within the rubber mould and then press into the holes around the door edge. The boot seal on a mini sedan is the same. |
