It is currently Wed Jul 23, 2025 10:47 pm
PostPosted: Mon Oct 15, 2007 7:22 pm
i have a set of mini rear door rubbers and i cant seem to fit them properly with the clips could someone tell me how to fit them properly they are the reproduction ones otherwise i will just silicone them on the rear doors :cry:
cheers damian
PostPosted: Tue Oct 16, 2007 5:37 pm
Can't really help with the clips issue, but I just stuck mine on with silicone. I did them bit by bit, holding them with clamps as I went until the silicone had dried.
Hope that helps
Mister White Keys
"He who has the most toys, Wins"
1963 Austin Countryman Woody
1964 Morris 850 Van
1967 Austin Countryman
1975 Range Rover 2 Door
2004 Subaru Forester XT
2015 Potts Teardrop Camper
RIP 1990 Citroen BX 16Valve
PostPosted: Tue Oct 16, 2007 8:14 pm
ok thankyou for the help
cheers damian
PostPosted: Tue Oct 16, 2007 11:53 pm
Hi, Try contact cement, its much quicker than silicone.
Clips usually fit into a slot within the rubber mould and then press into the holes around the door edge. The boot seal on a mini sedan is the same.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
