It is currently Sat Jul 26, 2025 4:56 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
PostPosted: Thu Oct 18, 2007 3:10 pm
Ok - the carb fell to bits - so I scavenged bits from another amd now its running again.
But - there is a always a but
I have the carb completely is leaned off - the jet is flush with the bridge - yet its running rough, bogs down under load,wont rev and is blowing black smoke just like its running rich.
The float lifter is making no apprecable difference to the idle speed or quality suggesting that is the mixture is fine.
I have run out ideas
PostPosted: Thu Oct 18, 2007 3:13 pm
is it on the right way up?
PostPosted: Thu Oct 18, 2007 3:15 pm
:lol: :lol: :lol: yes I it is
PostPosted: Thu Oct 18, 2007 3:24 pm
It sounds like your float bowl is stuck open. Take off the top of the float bowl and check the needle and seat is sealing.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Oct 18, 2007 3:25 pm
If its blowing that much black smoke then its raw unmetered fuel. Bell not sticking half way up.
Check the centering on the jet and needle.
Check that the fuel bowl is not to high or the wrong angle ?? and that fuel is just seeping into the motor.
Mike
PostPosted: Thu Oct 18, 2007 3:30 pm
Are the jet and needle both from the carb you used before or are they a mixture ?
PostPosted: Thu Oct 18, 2007 3:58 pm
they are the originals - the parts replaceed were the mechanical linkages to the jet.
I also just checked the float, the needle appears to be working and the float level is set correctly - 3/8 gap between the bowl topand the float whilst just contacting the needle.
But it makes sense to be that area
PostPosted: Thu Oct 18, 2007 4:10 pm
So maybe the float needle is cactus
I have only used grose needles before - are these ok for small carbs or I am better sticking with the normal ones.
I ll post this seperately - thanks everybody
PostPosted: Thu Oct 18, 2007 5:43 pm
The float needle is not the problem. The needle is working just fine and is sealing perfectly when its inserted in the seat. The floast also appears to be OK
So back to the drawing board
PostPosted: Thu Oct 18, 2007 5:44 pm
Is the needle centred? is the float full of fuel?
yep and yep
PostPosted: Thu Oct 18, 2007 5:58 pm
try changing the float needle & seat - they are notorious for wear.
problem must be in the float bowl region if its flooding
PostPosted: Thu Oct 18, 2007 6:05 pm
Blokeinamoke wrote:
yep and yep
The float should not be full of fuel....thats why they call it a float...sometimes they get pinholes...tis what I meant.
PostPosted: Thu Oct 18, 2007 6:09 pm
9YaTaH wrote:
Blokeinamoke wrote:
yep and yep
nup the the bowl is full of fuel - not the float - and floats in the bowl without striking the sides - so its centred - tis what I meant
PostPosted: Thu Oct 18, 2007 8:26 pm
Blokeinamoke wrote:
9YaTaH wrote:
Blokeinamoke wrote:
yep and yep
Excellent :!: the other needle I was referring to was the Jet Needle...does the piston move up and down smoothly without interference? tis what I meant :lol:
