It is currently Fri Jul 18, 2025 1:14 pm
PostPosted: Wed Dec 29, 2004 1:34 pm
Hi all just backed the car out of the Gararge where it has beed since I went on leave before Xmas. Now its leaking green blood from the water pump. It apears our local mini parts people are also on holidays. Does anyone know of anyone working over the break who may stock a water pump for an A+ 1275 ie 92 1.3L
Regards to all
From Paul
PostPosted: Wed Dec 29, 2004 1:38 pm
try karcraft if not PM me and i can send you the one i bought and i will just get another one.
karcaraft
97379944
Aaron
PostPosted: Wed Dec 29, 2004 1:47 pm
Thanks Aaron I'll give them a bell. How come you've got one or are they the same as "A" 1275 ones.
PostPosted: Wed Dec 29, 2004 1:50 pm
there the same, i have a hi capacity one with a bypass hole, if you have one that has no bypass hole no worries. It is for the motor i am building up for the van. so it's in a packet waiting to be used.
Aaron
PostPosted: Wed Dec 29, 2004 6:24 pm
Regret Karcraft are closed till the 4th January for a well earned break ! Your car should have no hole for by pass hose water to flow through. You can use the earlier pump and block off hole. Ensure pump has lage empellor. :P
PostPosted: Thu Dec 30, 2004 10:04 am
Thanks for the prompt reply, I will be on the phone early on the morning of the 4th. Unless I can get one before then. Should hold up for little longer!
Regards Paul
